Thanks to ALL for your help!!
How to make alkaline water?
Started by Tito L. Oracion, August 02, 2009, 10:43:55 PM
Tito L. Oracion
Quote from: dankie on August 09, 2009, 05:01:33 AM
http://www.youtube.com/watch?v=f-dpdC5FwBA
This water right here can cure cancer
if you drink enough of it regularly .
Combine this with some vitamin b-17 , hemp oil and you can cure any cancer .
Moshe goes to my site , he sells kits an will explain to you .
The annoying part is the filtration .
Do not mistake this water with "structured water"
Hi sir !
thank you.
robbosdog
Hi , this is how I do it ( the cheap way )
Equipment:
2 * 1 gallon jars
2* ½ gallon jars
1 * 304 stainless welding rod cut into 12 inch length’s
12 inches of cloth/hand towel
6 * small 9 volt Batteries
Some wire and clips
Options :
p/h test kit  ( strips / chemical / electronic )
Multi meter
Method :
Fill two one gallon jars with tap water , if you have a ph test perform one and take a voltage reading , should be around + 400 / + 500 Mv and ph 7
Series the nine volt batteries up to approx 50 volts and connect a wire to each end and a to a 12” length  of welding rod.
Place a rod in each container.
Roll the cloth into a wick and join the two jars .
Wait for 10/12 hours and take readings for each jar , the negative jar should now read ph 8+ and have a reading of â€" 300 Mv the other a p/h of 4 and a reading or + 800 Mv .
Only drink the alkaline water , the other acidic water is good for disinfection of wounds and sterilizing surfaces.
shouldn't cost more than $20
Hope this helps
Robbo
Tito L. Oracion
Quote from: robbosdog on August 09, 2009, 06:42:40 AM
Equipment:
2 * 1 gallon jars
2* ½ gallon jars
Some wire and clips
Options :
Multi meter
Method :
Hope this helps
Robbo
Hi sir !  ;D
nice info
Thank you very much!!!  ;)
God bless
otits
triffid
Please,Please,Please do not drink anything(water,homemade hootch) that may have metals in them.When you hear of people dying from homemade hootch.It 's because whoever made it used metal bowls,spoon's,Etc to make it in.And sometime during the process enough metals leached in to kill your liver.Just a warning.I have made homemade wine before and use no metal anything to make it with.Triffid
robbosdog
well  triffid , if we can't use tap water , stainless and glass for this , do you have any valid suggestions of what one could use ? , I find it a bit "alarmist" of you to  have responded in this manner when it is plainly spelled out what will be used in this process.
Robbo
