Thanks to ALL for your help!!
How to make alkaline water?
Started by Tito L. Oracion, August 02, 2009, 10:43:55 PM
Goat
Hi Tito
There are much better ways to create alkaline water than using baking soda which is loaded with sodium!
The easiest is Pure water (distilled or ionised) or Lemon water (pure water + fresh lemon or lime).
I bought a Lotus water treatment system (LWT100) years ago when I moved to the city because I can't stand to drink chlorinated water from the city systems, this unit ionizes the water which makes it alkaline.
Other ways is to reduce acid foods and include alkaline vegetables and fruits in your diet.
I just did a quick search on the net and found a website that lists alkaline vs acidic foods in a table format at http://www.essense-of-life.com/moreinfo/foodcharts.htm I am not affiliated with that web site and only list it for information.  There are tons of other sites that have information on alkaline diets.
Paul
triffid
I would say that baking soda solution could be used as an electrolyte for a battery much the same way salt water could be used as an electrolyte.But I think they use stonger alkaline solutions than baking soda in alkaline batteries you buy at the store.Triffid
onthecuttingedge2005
Alkaline batteries use Potassium Hydroxide as an Electrolyte base, Potassium Hydroxide is the strongest water soluble Base and is a benchmark for Electrolytes.
The Anode of the Alkaline Battery is Usually powdered (metallic) Zinc to increase Surface area of ion Exchange in the Electrolytic reaction.
The Cathode is made of Manganese Oxide which furthers the base region reaction between the Zinc ion exchange.
for a conventional battery Alkalines are low energy density power sources, it is better to make Aluminum Air Batteries using Potassium Hydroxide since Aluminum Air Batteries offer the greatest Energy density than any conventional battery although they are nonchargeable.
Jerry ;)
Tito L. Oracion
@ triffid, jerry and paul
Thank You very very much!!!
for these great info  :)
God Bless
otits
dankie
http://www.youtube.com/watch?v=f-dpdC5FwBA
This water right here can cure cancer
if you drink enough of it regularly .
Combine this with some vitamin b-17 , hemp oil and you can cure any cancer .
Moshe goes to my site , he sells kits an will explain to you .
The annoying part is the filtration .
Do not mistake this water with "structured water"
