Thanks to ALL for your help!!
Free energy, from a antenna. Tesla technology.
Started by Tommey Reed, August 05, 2009, 08:43:09 AM
triffid
The way the patent said the electrode surface area could be increased several thousand times was to dissolve the metal(electrode) into solution(mostly acid) and so the metal was atomized or free to react as atoms with other metal atoms.It does appear that the mass of the metal plate does determine how much energy you can pull down through a simple antenna system.But if you are able to dissolve the plate so its in atoms.The surface area may be greatly increased and you may be able to pull down a lot more energy.Just thinking out loud here.Triffid
Yortuk Festrunk
So how did Tesler keep energy from excaping from his cumpaciter?
triffid
If you mean his plates he did recommend mica to insulate with. Some experimenters today use laminated plastic sheets.Triffid
triffid
Some guy somewhere on the internet claimed to get 150 volts from an aluminum awning (22 feet by 8 feet )located just 8 feet off the ground.Think of all the aluminum cans that could be flattened and nailed together then insulated to make a plate.Triffid
the_big_m_in_ok
Quote from: triffid on August 28, 2009, 05:37:01 AM
That seems to be an awful lot of work using nails.  Super Glue might be stronger and easier?  Or why not use aluminum foil?
--Lee
