IST! NEO ZAP ARC REACTORS
Started by innovation_station, August 07, 2009, 09:03:50 PM
innovation_station
ok back at it ..
ingridents
a mot  MOT= MICROWAVE OVEN TRANSFORMER
and i got my sparker unit almost done ill add some pics  of this entire setup
same deal as the arc reactor but we will control this one ..  and not let it get too hot ...
a 12vdc realy a pulser fet driver curcuit ..
and ill add more to it soon including some neos to zap .. and a bulb socket to test with ..
pics ...
ist!
innovation_station
here is my you tube video of this driver circuit at work ...
ist!
http://www.youtube.com/watch?v=SBjN0wO05-w
agin there quite a few ways this unit as showen can be configured to operate ..
1 way im considering is take the colapse from the relay send it throuth the gap to a full wave bridge then to the mot ...
or ....  honestly many ways ...
if i keep the colapse cold probally no heat at the the gap then ....  if i use hot power with a few amps ...  than it will run hot at the gaps and the unit should be wired a little diffrently .. this will work too ..  but in this unit it must be pulsed   the relay in that configuration should run slow ...  slow pulses at close to the speed that the core material can handle ..
the first way ... the relay is required to run fast ...   i know the colapse of the relay can power the mot as it has blowen fets on me in the past .. so ill work out all the details ...
and post as i go as i do
rave154
right there with ya IST, got my MOT & realy & 555( at the moment its hooked up to a mosfet, but can switch over np's )........lets goooooo 'disrupt' some.
David. D
innovation_station
Quote from: rave154 on August 08, 2009, 09:47:12 PM
David. D
im verry happy you came to join us here bro !!
you have a verry intresting video on youtube ...  ;D
awesome work ....   i must say!!!!
well lets build her!!  and video demo the entire unit once built ...
W
btw     my relay is dubble pole dubble throw ...  cuz we can do npn and pnp mechanical switching with it if we build it accordingly ...   to do this we must protect the relay i have melted down relays in the past same way the carbon rods glow bright red ...  so how about a bridge off the switches ... so it can not back flow to the relay  ;D 8)
i look at my unit and i come up with toooooo many ways to build it ... this has always been a problem of mine and i cant draw schems well at all ...
im useing an irf 840 ... mosfet   it is a npn unit  so it is much the same as the jt ...  in the way i recover from the fet it has built in recovery as i was gonna use a 12vdc battery controled by a freq genny ... by original design for the bords ... i have built ..
so the fly back off the relay was to recharge the driveing battery .. but
we will complicate things a bit to iron out the buggs  ;D
this is what i think i may well do with this unit ..   i will use the driver as showen it is a pwm circuit but off the fet i put a bridge ..  to a cap so
this is what i see happining in my mind in a single pulse to this part of the system
the fet turns on at the rate we choose from the pot and the cap  this is doing only neg switching to power the relay coil only .. when we turn off the fet the relay coil inductive flyback back flows right back to where it came from ...
ok so now as soon as we turn on the unit the engery flows to switch on the relay but if we have a bridge rectifier on the input \ return flyback ...  ps across the fet ....  and a recovery cap ..
then it wil turn on the relay as well as fill the cap to the driveing voltage .. of the unit ..  now when it shuts off it flys back but can not return to the leds and is only allowed to fill the recovery cap to a much higher voltage .. basiclly you tell it where to go ...  much the same a portection on the bedini only redirrect to a cap ...  wich will have a bleed off diode from the cap back into a recovery battery ..  this can run with 1 battery or 2 as in the ist 808 sky coil ..  or the tesla switch ...
same same then when the 1 gets low flip it to the other that is recharged and just flip the recharge diode as well ...  so bedini ..  this is the RELAY COIL ONLY FREQ GENNY AND FET THE LOW VOLTAGE END OF THE CHAIN ...
this will offer self chargeing  continual or perpetual driveing source ..   and protection from the spikes that can harm the driveing gear..
now basiclly the same on the relay contact side of things but we will use high amp rated bridges on this side and we will pulse pnp and npn in sync on the higher amp end ...  the mot input and spark gaps ... since i have choosen both pos and neg in sync  i will likely reverse the rods on the spark gaps accordingly so that the bronze will remain colder at all times in both dirrections ..  and the carbon can get hot ... it will not affect it as i have seen it still loves to work ...  then we could add neos in the gaps in the proper oreintation  or we can quench the gaps as tesla did ..
sooo many ways ...  for now i will work on the relay unit the low voltage side ..
i had to replace a led in the board as a kick blew it up some time ago ...  so it needs some mods nothing is perfect at first crack and that was the first unit i built aside the bread board ... i have built many the exact same as this board ....  they apear to work well ....
we will  get the low end recovery down first tho ..
ist!
rave154
IST,
im not sure exactly which video youre referring to, i did have one also of me putting a 12v 100mA bulb in a glass of water while the HV from the ignition coil was across it, but i took it down in case young-uns saw it and thought it was kewl and tried to do it.
i have 4 identical 30A, SPDT auto relays here ready to go.
i got NEO's up the wazooo ( that didnt come out sounding right ! ), 2  MOT's, 4 ferrite donut magnets from the micros, bulbs, and transistors etc galore, the full works.....lets do some disruptin.
