Back to Basics
Started by Grumpy, August 10, 2009, 09:48:27 AM
0 Members and 40 Guests are viewing this topic.
turbo
Quote from: Grumpy on August 15, 2009, 01:29:57 AM
Do you think my posts are just idle speculation?
They are.
If you want a "how to" guide - write your own.
I am actually doing exactly this and the first three lines make more sense than all your posts grouped together.......
Why?
Because they are a result of experimentation, and you can't beat that with all of your guesswork!
innovation_station
how does a tpu work what is THE CORRECT OPERATION OF A TPU
well now LETS HAVE A LOOK  8) :o :o :o :o
IST!
http://www.youtube.com/watch?v=G3eI4SVDyME
INDUCTION ....  ;D
A CHANGEING MAGNETIC FEILD...  HUMMMMMMMM 8)
PEACE X2
W
PS HELL WITH FUNDING ...  I MAY WELL KNOCK ONE OF THEASE UP TODAY!!
SPEEKER WIRE ...  IRON RING ...  4 JT 1 RING ....  ALL SAME DIRRECTION ... PULSED 1234 1234
EACH JT IS THE SAME TURNS AND WIRE LENGTH ...
KEY TUNE TO THE CORE MATERIAL ...
JUST CUZ ITS THE BDAY .... ILL BUILD 2 ONE WITH A CUT CORE AND 1 WITH A SOLID RING CORE ...
sparks
   You will note that in SM devices there always appears to be two collector windings.  Upper and Lower levels and in the masterpiece crossection we see upper and lower collector rings again.  I imagine we could call the collectors stacked.  Now if we take a bunch of coils and space them apart so that the magnetic fields interfere constructively and if Leedskalin is right as the current flows through the collector windings magnetic particles will flow from one torroidal magnetic field to the next.  This will transfer energy from collector A to collector B.  If there is a torroidal flow of magnetic particles already established in the Earth field as there appears to be then the Earth becomes just another part of the stack.  If the stacked torroidal magnetic fields take on a cone shape  eg Tesla's magnifying transmitter then the small torroidal magnetic field at the end of the stack experiences an acceleration of it's torroidal shell magnetic current like water flowing through a raceway trying to conserve inertia. So magnetic energy is concentrated in the final stage in the form of a high speed magnetic dynamo current trying to keep up with the flow in the big torroid.  Like having this giant gear spinning a tiny output gear.  Now we need to have some change in the magnetic circuit to convert this highvelocity magnetic current into a bumpy one so conventional induction can occur.  We need a magnetic valve.  Enter the kick.  The kick closes down a magnetic valve very quickly and the flow now has some vibration or wave properties to it.  You could close the valve at 5000hz or whatever as long as it is efficient.  SM was an audio engineer so 5k would be a frequency he is well versed in dealing with.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
Thanks for everyone's input.   This thread has served it's purpose.
EDIT:
Marco,
Go ahead and post your "how to" guide.   Post all your experiments and your interpretations and conclusions.
Go ahead and post a working energy-producing device that utilizes these principles.
Go ahead and make everyone's day.
        -Frank Edwards
MACEDONIA CD
@grumpy
did i have tell to everyone here that @marco is  issss  not good friend
maybe marco is here  for anather reason here MAYBE  <PUT ALL FRIENDs DOWN  >
