Thanks to ALL for your help!!
Steven tells us how the TPU operates Look and Listen.
Started by adasta, August 14, 2009, 02:16:38 AM
Magregus
It's all about frequency, everything is about frequency.  You can burn water with the flippin right frequency, you can melt metal with the right frequency.  The neodymium + coil + something else produces a frequency.
innovation_station
Quote from: Magregus on August 14, 2009, 10:03:42 AM
that is a verry intresting statement!!
what freq does it produce ... ?    the freq of electricty ?
hummmm
ist?
sparks
You generate uv frequency it messes with the space between electron and neucleus and you ionize water vapor then pop it.  You generate gamma radiation the wavelength is small enough to take apart a neucleus.  Beyond that frequency you start activating sub sub atomic particles.  These hf frequencys could be permeating everything everywhere and keeps the whole deal energized. Matter of scale.  Dealing with near infrared emwaves is what people run on.  If I could run this shitbox I'm in on infrared maybe I could afford to turn on the AC. Tesla that mofo converted hf to lf probably ran his shitbox on emwaves in the nearinfrared seems to be no lack of them round here.  Then he goes nuts and builds some Tower that he is going to transmit juice from all over the planet.  Frigging uv generator setting up a new plamasphere. Hit some air with a uvlazer it ionizes the shit and now you have a wire from target to generator.  Put some potential between target and ground watch the poor bastard fry or freeze on demand.  Tesla should have stayed with the automotive industry instead of trying to cater to the military.  SM who knows?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Qwert
Hi.
Below is a short quote of a longer article which can be found here:
http://www.overunity.com/index.php?topic=937.msg7034#msg7034
Notice that the author of this article mentions here the 5000 Hz freq.
Quote:
29 September 1997
Michael Fennell  (Consulting Engineer)
8348 Menkar Road
San Diego, CA. 92126
To whom it may concern:
I have been hired by Mr. Green to evaluate the performance of the Toroidal Power Unit or TPU as has been described to me as a proprietary invention of Steven Mark who was until 1995 President and Chief engineer of Spheric Laboratories, a public corporation.
I have been instructed to compare the performance of the TPU with that of any known batteries and other storage systems.
As understood the device is universally observed to have the following characteristics:
Outside Diameter:  6"
Inside Diameter:  5"
Height:    1 - 3/4"
Weight:   12 ounces
Output Power:   250 Watts
Output Voltage:  160 Volts
Voltage Frequency:  5000 Hz.
Duration of Performance: 30 Minutes
To compare the TPU with commercially available and developed batteries I described its performance in terms of -Specific Energy-.
End of quote.
Justalabrat
In this video,  http://tinyurl.com/lafv7v ,near the end, Steven Marks takes the 6" TPU device outside. Once he is outside he connects a 100 watt bulb to the terminals on the coil and it lights up. Well the thing is, the center of that coil has nothing but empty air! Where are the control electronics? Now there is a little bump on one end that looks like it could be a small circuit board covered in electrical tape, It looks like it could be about 2" x 2" or so. Has this been discussed here somewhere on the forum?
