New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
0 Members and 256 Guests are viewing this topic.
teslaalset
Quote from: winsonali on November 11, 2009, 07:49:17 PM
My question and help needed is
to produce electric power i am using non magnetizeable material in a magnetic environment
if any one can send some links to magnetic properties of materials (like alloys of aluminium , zinc and brass etc) so i can make use of some more better material for my experiments
Ali, maybe below link is what you want?
http://www.tpub.com/content/NAVFAC/hdbk419a_vol2/hdbk419a_vol20181.htm
Have you thought about possible Eddy Currents that may effect your device?
Eddy Currents may cause extra loss in case you move non magnetic metals in static magnetic fields, or use static non magnetic materials in moving magnetic fields.
In particular cases it helps using materials in thin layers (laminated) to decrease losses caused by Eddy Currents.
wattsup
@winsonali
I have followed your video and a good part of this thread. I like the basic idea of your device.
I am assuming that the operation of Genie's main circuit is DC as you say 40 volts. So why not just run it with 4 x 12vdc x 7amp batteries and do away with the 240AC feed requirement, then show your demo with rising, falling or steady battery voltage. If the voltage drops, refine it. If it does not drop, bingo. Or show two demos, one with 48vdc batteries driving a number of lamps at very low brightness without the genie showing how fast the voltage drops on the batteries. Then another demo with the genie showing the lamps very bright and battery voltage not dropping at all or not as fast.
This will get the main point across to both high level and most importantly low level techs (like me) to quickly understand it.
The batteries could also give you a place to land any flyback, should there be any in your system.
The problem with running AC and a watt meter is that people will always say the harmonics created by the Genie is tricking the watt meter readings. This would not be the first time. Only once your device can operate with an easy to show DC feed, that people will then accept the AC feed via a step down transformer and an AC to DC bridge rectifier.
Also, if you plan to make another video, maybe consider speaking a little slower, try pronouncing your words fully and it will not look like you are trying to sell the next Miracle Knife or ShamWow Towel. In such a video you are not speaking to your local friends but to the world. The aim of any such video is viewer comprehension so please take my comment as only a constructive criticism.
As for your request for suggestions on non magnetizable material, if it has to be a metal, of course aluminum would be the first to look at but what about titanium?
I am a fan of what you are doing and would consider purchasing a genie device when it is available to test it out and then buy some more afterward.
All the best.
winsonali
Teslaalset
Yes i was looking for the same information you have given...thank you
in all generators one part is always stationary.
I was basically designing input section of genie without a dimmer with AVR capability then i think about using permanent magnet in a transformer that experiments failed and i saw number of patents dating 1954, to 1978 and i also review Tom Beardom's MEG i realize something is not right in this method and i developed this new technique of using magnetic field with out inter crossing and produce good  use able electric power. These are really new lines of working with magnetic fields this involves highly precise sensing circuits and software
Few results of my experiments raised these questions
1) what is the speed of magnetic lines
1A) what is the frequency of magnetic lines.
1B)  what is the resonant frequency of any magnetic material.
1B) an aluminum wire coated with silver offer good conductivity(current travel on surface area), but eddy current is highly reduced
2) why a stationary magnet do not produce eddy current or electro magnetic current in a coil which law define this part?
3)  an air core coil when in operation produce and offer electronic characteristic showing blocking AC current, exhibiting current lagging , LC circuit acts like pendulum , but it don't attract metal as a magnet until and unless it has some permeable material experiencing its current flow
in my experiments i am developing methods for  reducing the eddy current loses, inter crossing of magnetic forces even then you can generate good amount of electric current
these are really new lines of working with magnetic field This involves highly precise sensing circuits and software
Wattsup:
thank you brother for your support.
in my circuit we are siphoning current we require negative current below zero and positive current as well just like in a single phase line due to this reason we cannot directly feed DC current into genie
i listen to every one very patiently and don't mind what they are saying i take good knowledge from there discussions
all the above discussion is coz may be some one out there working in the same area can give me good advice or by looking at my work can improve his own work in either way we are helping a community looking for developing green energy
i will send unit free of cost to you before releasing in market coz every single word of support and knowledge is a contribution toward development
a simple question to everyone this is leading towards new concepts
why we use aluminium disk in a power meter?
hartiberlin
Hi Ali,
why don´t you use 2 x 12 Volts Batteries in series for your input
and use one battery for the positive input and one battery for the negative
input ?
This way you have positive, ground=connection of both batteries in the center
and negative potential.
So where is the problem ?
Regards, Stefan.
winsonali
hertiberlin:
DC batteries always generate zero or positive
they never have below zero level, inverted polarities do show on meters -ve pole but they are reverse polarity not below zero level
we need negative and zero
