New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
GOTOLUC
one thing just imagine if you remove the counter weight from a piston in petrol engine what will be the effect on engine performance
equivalence in electronics
collection of BEMF in capacitor or battery.
remember bemf is not a energy generation, its reversal of unused energy during switching cycle.
Just think if you remove fly wheel from the engine gear box what will be the effect. Fly wheel provide smooth power during the gear shifting period and works as smoothing effect between power loading and unloading on engine
use of high storage capacitors in supply's initial phase guarantees the smooth power output during transition period of switching cycles.
allcanadian
@gotoluc
What Ali has demonstrated is perfectly correct, in fact all modern boost converters use this very process to increase efficiency. The inductance is switched faster than the natural resonant frequency of the core material, in this way the current on the output "appears" continuous because the current never stops completely. In this case the source charges the inductance for one portion of the cycle and the inductance acts as a source in itself in the next portion of the cycle. If the magnetic field is allowed to collapse completely then the inductive circuit is referred to as a flyback converter if the magnetic field is not allowed to collapse completely then it is referred to as a boost converter.
AC
gotoluc
Wow Ali,
thanks for taking the time to post all this information.
Here is an interesting effect I just found a few hours ago while studying generator coil effects and possible solution to prevent Lenz Law in generator coils.
I have tested the coils in this flipped arrangement on a motor turning a magnet wheel and they produce just as good of output if not better then in normal mode but with next to no Lenz Law effect.
Link to video: http://www.youtube.com/watch?v=PTykNjDD0CM
Let me know what you think.
Luc
Luc,
I looked at your clip.  When you flip one of the coils around then the two coils cancel each other out.  That is why you are feeling hardly any force when you move the magnet by the pair of coils.
There is no point in building a generator like this.
gotoluc
Quote from: MileHigh on December 13, 2009, 11:05:29 PM
Luc,
Hi MileHigh,
I thought this could be the case, so after I found this effect I tested the coil on a motor that is turning a 10" Lexan disk to about 1,500 RPM which has 8 of 1" X 1/8" N42 Neo's counter sunk and epoxied in a north south alternating pattern.
First I connected one coil to a 1 Ohm load and 60uf motor cap and approached the coil to pickup the best voltage on the load which was 1.30vac. I then added the coil to get no Lenz effect and retested using the same load and got it to 1.20vac with the coil at about the same position. I'm doing this by hand so at this time I don't have accurate results but it looks very promising to me.
The video below demonstrates a prior test (not the same as I just described) but should give you an idea of how I tested it. Just keep in mind that I used a 1 Ohm and not a 10 Ohm like in this video.
Link to Video: http://www.youtube.com/watch?v=ebybImidcFY
I hope you can find the time to replicate and help spread the news.
Luc
