Thanks to ALL for your help!!
New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
forest
Yes,that's possible but quite complicated (probably needs a microcontroller)
listener191
Quote from: forest on November 30, 2010, 03:45:39 PM
Well the basic scheme I am building is using 4000 CMOS, so it is not so compact as a micro controller. The floating drivers for the series MOSFETS are a little more complex. I have a scheme using a capacitive coupled floating DC supply for each driver. The drivers are opto isolators (photo transistor). A better choice would be photovoltaic couplers, as they develop their own DC for driving the MOSFET gate and this would be simplest arrangement. Winsonali had difficulties in this area, due to lack of hard MOSFET turn on. I have kept away from bootstrap dedicated driver IC's, as they are too fragile for experimentation. I thought I would get the basic scheme working as a voltage controlled sine generator and then explore from there.
gyulasun
Normally voltage multipliers do not increase output power but voltage amplitude. Have you considered this?
Sorry to ask this but unless you know a trick or two you would not get extra output I am afraid.
listener191
Precharged capacitors i.e. ones not completely discharged, can be used in voltage multiplier converters with an efficiency of 95%.
I would expect this device not to be any more efficient than this (at best), but I want to explore what Winsonali was referring to as resonance within his circuit. Of course building this in stages is required to realise this.
winsonali
http://www.youtube.com/watch?v=ZnPu6b6K7Hc
i have used the same technique in developing energy saving fan this video is an exhibition where we have displayed the energy saving
the voice in video is bit distrubed and i have no information regarding this an on my website  i am still researching in the same area
