Correction...TPU Steven Marks Earth's MAGNETIC FIELD....oops.
Started by leeroyjenkinsii, September 03, 2009, 07:25:24 AM
leeroyjenkinsii
I got a nutty idea folks that I demand you take entirely seriously.  Ok. So we know we can create an electrical flow from a shifting/pulsing magnetic field.  We also know that the earth's magnetic field is not shifting but constant.  How do we generate electricity from this?  We clearly can't make it shift but maybe we can pulse it to a collector.  How do we do this?  We have to create a magnetic blocker and turn it on and off at some frequency to allow the current in the collector to move and be picked up.  This magnetic blocker has to have a lower electrical cost than the electricity collected.  What can be used to block the magnetism for a period?  Can plasma block a magnetic field or perhaps another magnetic field from the coils around the collector?  Can the coils around the collector not only block the earth's magnetic field at a given frequency but also channel that energy as well somehow...perhaps during the de-energized phase of the cycle.
So my theory in essence is block the earth's magnetic field....unblock the earth's magnetic field creating a pulse and collect this electricity...block the earth's magnetic field....unblock and collect, etc. etc. I suppose the higher the frequency for this the more electricity can be collected.  Also if you can use the energy during the blocking phase as well then that would be great too.
Let me know what you guys are thinking about this.  If it sounds possible but you have the urge to knock it don't.  I could care less who takes the credit if it works.  Hell I'll probably forget I posted this.
Also, it seems that great resonance would benefit this process to such as the techniques used at witricity.com.
Tito L. Oracion
Quote from: leeroyjenkinsii on September 03, 2009, 07:25:24 AM
hi leeroy good day
Actually we have the same question, but i have a suspect that they uses some kind of yin and yang technique to control the strong energy of the earth's magnetic field by squeezing or making concentrate in the middle into a very high speed to generate or make a flow of electricity.  8)
regards
otits
leeroyjenkinsii
Hey thanks for the reply.  Please keep replying as I felt kinda lonely on this one.  I have a modification on the direction of this now.  According to the link below the earth's magnetic field is not very strong.  Also according to the second link below there is no material that can "block" a magnetic field.  However, it can be redirected.
Given this info and some of the videos I've watch with SM placing magnets in his devices I am wonder if he's using the constant magnetic field from the magnets, redirecting the magnetic field off of conductive coils and then removing the redirection.  If this were done at a high enough frequency and if the cost of the redirection were less than the electricity produced in the windings (coils) then it appears you could have an electrical gain.  I wonder if creating an electromagnetic field around the conductive coils would repel, redirect (essentially keep the permanent magnetic force off of the coils) then releasing it allowing the magnetic force back on the coils to produce electricity would work.
http://www.wisegeek.com/how-strong-is-the-earths-magnetic-field.htm
http://www.physlink.com/education/AskExperts/ae512.cfm
Yucca
Hi leeroyjenkinsii,
The earths mag field is shifting. Schumann resonance causes an oscillation (7 ... 8 Hz) with amplitude of approx 1 picoTesla. Granted, this is miniscule (40 million times smaller) when compared to the steady state earth mag field of approx 40 microTesla.
SM states in the FTPU vid that the device is felt to vibrate slightly at 7.3Hz, if he wasn´t bullshiting then it may be coupling to schumman.
It is conceivable that the device operates as a unidirectional active antenna pointing skyward. perhaps it establishes a very large virtual antenna volume in the atmosphere above which encompasses billions of cubic metres (trillions of litres). If even a 1picotesla oscillation could be harvested and rectified from such a large volume then it could provide appreciable power.
Observing known physical behaviours we can see this happen already in the case of atoms. They are tiny when compared to the wavelength of light yet somehow they are able to absorb and be excited by radiation at light frequencies and below. It is because the atoms generate a dipole that reaches out far beyond the outer physical atom boundary (electron shell) this virtual dipole is able to efficiently absorb wavelengths of relatively large sizes. Physics books don´t cover this, but they do state the physical size of atoms and the physical size of EM waves that they are able to absorb, but they are lacking when it comes to explaining how an atom actually absorbs this relatively large wave signal.
The TPU is probably an active antenna, some power is used to establish this large receiving volume above it but more power is received through it as it couples on a large scale to this miniscule (schumman) oscillation.
If this is the case a TPU may only ever be an exclusive device, if two TPUs were operating under the same patch of sky then perhaps they would have to share the available power. But then maybe the resonating cavity (ground to ionosphere) might be replenished readily (from solar particle interaction) whenever power is drawn from it.
edit:
your idea of blocking and unblocking would work too, but the earths field is only 40microtesla and if we assume a TPU to be say 500ml in volume then that comes out at small power. It would be more powerful if you could put a monster neo mag above the device and somehow block and unblock the steady field emenating from that. Of course if you could work out how to do that then you could also build mag motors too.
leeroyjenkinsii
That's funny.  Your suggestion in the edit portion was the exact conclusion I came too.  So you think it would be pretty difficult to block or redirect the magnetic field?  Maybe the redirection idea is where to start.
