IST'S FURNACE FAN PULSE MOTOR SELF RUNNING NO INPUT BATTERY
Started by innovation_station, September 04, 2009, 08:53:09 AM
innovation_station
 ;D ;D ;D ;D
i just got back with a truck load of SPOOLS ...  ;D
I MEAN A FULL TRUCK LOAD ... AND IM BACK IN 2 DAYS FOR ANOTHER
THE ONES I PICKED UP WERE AROUND 3.5 TO 4 '  TALL AND THERE MOSTLY PLASTIC ...  ;D
I WAS GIVEN ALL THERE SPOOLS ...  8) 8)
I EVEN MANAGED TO TALK MY WAY INTO A STEEL SPOOL JUST THE SMALLER ONES AS THE BIGONES ARE 8' TALL AND HAVE A 600$ DEPOSIT ... THE SMALL STEEL ONE IS ABOUT 5' TALL
WILD TO SAY THE LEAST
AND I DONT WANT TO TALK ABOUT THE FREE COAX THAT CAME ALONG WITH THEM ....  ;D :D
AND I GOT SOME BAD NEWS .... I JUST MISSED OUT ON 30 OF THEASE  2 DAYS AGO
BUT ITS OK AS I GET ALL THE REST ... IT COST THEM 2000$ TO GET RID OF THE 30 I SPOKE OF ...
SHEESH ...
IST!
BTW THE SPOOLS IM TALKING OF 4 OF THEM FILL A HALF TONNE TRUCK ...  ;D
spools  ;D
innovation_station
im already on it ...
just incase you thought i wouldnt build it...  ;D
ill add a picture of the rotor im building from 2 wire spools 1 plastic spool from fiber wire and a wood one  the darn thing is heavy and big  ;D
its bout 6" thick by 4' across
i have an axel and bearings i will mount it on ...
ill probally get a bigger spool and build the entire unit inside the bigger spool ..
ist
of course ill still build the smaller unit from the furnace fan ..
here are some pictures as EVERYONE LOVES PICTURES TOO LOOK AT!!
last picture is the bearings and axel i plan to mount it on ..
this came from a 30 hp induction motor ..
and the really big motor units i PLAN ON BUILDING
will be mounted to a trailer frame .. and built to be towed .. just drop it off ..  :D   with the electrican ..   ;)
im goning to build a fleet of em  ;D
probally lease or rent them out ...  :)
ist ...  changeing this small rock in the universe...  8)
infringer
I do not understand you claim this great thing yet do not give any explanation to the working or even a theory on how you believe it will work IST I love your flare and love for free energy movement but please don't leave us out of the loop of learning... I am at a stand still with my project until I get some mail or email to figure out the route I wanna take in the mean time I think this is a rather interesting project so please do tell how you expect this to work ...
Thank you sure title says pulse motor which is dandy how about telling us how you think this will work so someone could make the decision weather to follow this or not.
Thank You buddy,
-infringer
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
innovation_station
ok
;D
here we go
this is easy ... so drop all big words and bs we all were tought ...
i will have a cap on my power source insted of a battery ...
i will use microwave magnets ...  most likely 24 around the edge of the spool this unit will stand vertical ..
i will use the END CAPS FROM THE ORIGNAL INDUCTION MOTOR TO SUPPORT THE MOTOR ..
ill add pictures of the parts i will use ..
there will be only 1 drive coil on this unit ... as i want to stay safe ... i dont want to run it too fast right off the bat!
i will use an old spool from speeker wire for my pulse coil  ill add the pic..
OPERATION OF THE MOTOR ....   i will only focous on the motor right now ...
i will after it is all assembled  give it a good push to start it ...
the cap will be shorted to insure there is no power in the cap .. there will be if needed some aditonal collection coils around the outside of the rotor .. i can have lots if i so desire but i like simple and not too much work ..
each coil i will put there will be bridge rectified . then sent to the primary cap..
lets call it the primary cap for 2 reasons ..
it will power the primary drive electro magnetics  of the motor ... all ext coils will feed generated engery and colapse engery into the cap .. so if the motor goes round 5 full revolutions or less... it will have filled the cap enough to turn on the pulse motor circuit!!
;D
see simple ...
yes indeed this is how simple it is to make a self running motor it is sad tho that i had to explain it ...  :(
ist
but its ok as i do not mind ..
innovation_station
i have changed the rotor ..
i am makeing 2 units right away ...
;D
so my rotors consists of 3 wire spools this will build 2 pulse motors ..
1 wood spool 2 plastic spools ...
each rotor has 3 peices to it  i will bolt the 3 as 1 rotor with a few bolts .. last thing i want is for it to  fall apart under high rpm ...
the rotors with out anything .. on them mesure 42" across each and 6 " there bouts thick
ill add up dated pictures tommorow ..  im moveing them into the shop to fasten the microwave magnets ..
1 rotor will use microwave magnets... i could probally fit 36 no problem around the edge ..
the other rotor is the exact same ..
it will have my 10 neos 1' wide by 2" long spaced evenly around the edge ... and ill test them both ..
I HAVE BUILT ENOUGH PULSE MOTORS TO KNOW MY OUT COME ...  ;)
IST!
BTW EACH ROTOR WEIGHS BOUT 120 LBS BARE AS THEY SIT...
