Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
FreeEnergy
Quote from: maw2432 on December 15, 2009, 09:17:22 PM
Great work Yu.
For those looking at the equilibrium position being shifted right or left check this out.
http://www.youtube.com/user/gotoluc#p/a/f/2/w9P3Rh3Q_gI
If the magnets are shifting the equilibrium in Yu's machine then this may be just another way of explaining what is going on.    Looks like a possible way to get OU to me.
Keep up the good work Yu.
great video!
this is a much easier way to keep the pendulum swinging with very little input. over unity is so near i can smell it.
peace
WattBuilder
ALL,
I just got my shipment in today of a wind turbine.
It’s a Ginlong 500A and the wiring setup is for higher amps.
Here’s a link to the specs
http://www.ginlong.com/wind-turbine-pmg-pma-permanent-magnet-generator-alternator-GL-PMG-500A.htm
It’s harder to turn with my hand then I was hoping for but I guess that’s because it contains very strong neo magnets.
I’m going to try to break in the bearings and see if that helps.
Happy Holidays   :D
Howard Yu
maw2432
Yu   very nice generator.  How much in US dollars?
Keep up the great work.
WattBuilder
Maw2432 and FreeEnergy
Thanks guys for the support! I have been getting great responses from people all over the world. Thank you all so very much. I do feel bad I haven’t been able to respond to all as I would like to but I will try to do better as my workload allows.     :)
@ Maw2432
That cost me $450 plus shipping. I don’t recommend the replicators to buy one just yet. I still need to test it out first. My plans for it has many purpose other then the OU YOG Model. I plan to use it for the Wind YOG model as well, So for me I can justify the expenditure.
Right now I’m at the step function part of the OU YOG Model. I have two methods that I still need to test out to be sure. One with input electricity and one without. Hopefully I can avoid scaling it up but a lot of the results are pointing towards increasing the gain strength of the array.
Well, stay tune guys, as I will be posting results as they develop.
It should be around after the Holidays.
Howard
Basic magnetic array track. A review of attraction vs repulsion
http://www.youtube.com/watch?v=yYY1y3EA6iY
WattBuilder
ALL here and ALL sending outside replies,
I’m ready to release the method that I feel is better than the wind vane method.
This will remove any input electricity needed for the YOG.
There have been a lot of great replies on orientating the drive magnet. Thank you all very much for your suggestions.
This method is called the “Magnet Throw Method” and the reason why I decided to choose this route is because I feel this will be easier for the replicators to build and confirm this technology getting it out the door. Note I have not build and tested this method yet. I have been going over this for a while now and it’s time to release it.
This method uses a small lever to throw the drive magnet forward. The small lever has a magnet on the bottom end that will temporary hold its position while the counterweight launches the main lever forward causing the flip while passing the fixed magnet.
Once the drive magnet has completed its flip the counterweight will allow the small lever to release its position without loss of kinetic and gravitational potential energy. It’s as if I was releasing it at the start position, which is the point of the fixed magnet.
I hope I this was able to explain that clearly.
Sometime after the holidays I will be posting the results.
Happy Holidays
Howard Yu
