Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
WattBuilder
Jim,
Ooh, I see what you mean..  Good point.
But I’m not able to add that function into the YOG.
The YOG is global patent pending and that function will resemble too close to the 2 stage oscillator. I don’t want to be infringing on his patent.
Besides I think mine works better then his!   ;D
The YOG center of gravity is suppose to shift, that’s what allows the lever’s drive magnetic to return back onto the magnetic array and also allows the weight of the lower pendulum that is a lot greater to come back down turning the turbine
Quote from: P-Motion on September 23, 2009, 10:42:56 AM
Otherwise the law, Conservation of Energy would suggest that entropy would keep it from working.
Not really? I heard that word use in two ways.
If it’s used as thermodynamics then it does not apply.
If it’s used to refer as “slowing down” then that’s not a problem.
Because the kinetic energy of the pendulum and the magnetic push of the magnetic array will launch the drive magnet out. Then the next cycle repeats.
Any loss of kinetic and potential energy due to air resistance, bearings, turbine load and what ever can be think of. Gets replenish when the drive magnetic goes through the magnetic array.
Howard
WattBuilder
Hi Jim,
I’m not familiar with the Mag-Lev and Johann Bessler work too much, But I will look into it a little more to catch up.
To those who are building the YOG for testing, I want to point out that the HJ track has different versions.
If you decide to build the round and square gate looking array. That array only goes one way but it has a stronger force then the bi-directional array. You will need to rotate 180 degrees out of the array vertically. So that the return swing will have the drive magnet out of the array to swing freely back.
If you decide to build the bi-directional array where the array magnets are all north. Then continue as I was explaining to rotate 180 degrees horizontally.
Either way will work just as good….
I will be on a trip and will answer questions upon my return whenever that may be.   ;)
Howard
WattBuilder
For the readers who have decided to build the YOG for testing.
There is a way replace the input source electricity.
This can be achieved by removing the servo and adding a Tail Vane instead. This method will allow for basic aerodynamics to do the work.
In order to allow the tail vane below the drive magnet to rotate 180 degrees. You will need to add a bearing, so it can change the orientation of the drive magnet facing towards the magnetic array. If you happen to choose an array that tries to turns the drive magnet. You will need to add guide rails next to the tail vane to keep it true.
Note: this will only work for a bi-directional arrays.
I am almost completed with this test unit using the tail vane. That I originally had plans for teachers and educators. Hopefully in the coming weeks it will be ready for videoing.
Howard
WattBuilder
To all,
Here is my latest video. Showing how the YOG gains energy from magnets.
http://www.youtube.com/watch?v=gekDM8vg16k
This is just an analysis of the YOG’s one cycle.
Enjoy
Howard
spoondini
Howard,
I see themerit in your plan.  I believe it possible to use gravity to reverse the direction of the magnet on the end of the lever.  I can't express to well in words, but if the magnet is mounted on a rotating plate with a weight behind it, at the end of each cycle the weight would continue moving forward thereby rotating the plate and reversing the direction of the magnet preparing it to pick up energy on the next cycle.
A little wary of the fact your already taking orders on your website before a working model has been demonstrated.  It's a neat idea but a quick way to loose street credibility.
