The Electric Field: Testatika, Lifter, Piezo, Diode, Crystal battery
Started by PaulLowrance, September 30, 2009, 11:42:20 AM
PaulLowrance
PaulLowrance
More diode experiments,
http://globalfreeenergy.info/tag/diode-experiments/
BTW, only the recent diodes were LEDs, but most of the diode measurements were from normal diodes with solid opaque casing. All of the shielded diodes produced DC current & voltage. Contact me for measuring setup details because you can't stick a normal volt meter on a diode due to the meters low Rin.
If you want to use a normal low Rin volt meter, then you can have the diode charge a low leakage capacitor inside a thick metal shield, wait ~ half a day, and then use a normal volt meter. Just do the RC time constant calculations to see how fast your meter will discharge the cap. A 10Mohm Rin meter will work good enough with a 1uF low leakage capacitor. Or just get a $40 AM-240. AM240 is ~ 15Gohm Ri.
Regards,
Paul
PaulLowrance
My following recent replies from a few minutes ago are being placed here since this is more appropriate thread -->
Hi Mark,
Actually, IMO the fact that conventional scientists, and ~ 2 years of extensive measurements not revealing the source of this energy, makes it exciting because it's most likely a new discovery.
It can not be due to radioactive materials in the piezos or diodes because of the effect I've described from the beginning of the research experiments 2 years ago, that used to be called the TED effect. That is, it is extremely easy to disturb the diodes ability to produce the voltage. Even applying a few hundred *pico* amps DC on the diode (e.g., from a common voltage meter) can place the diode in the disturbed state for 2 to 3 weeks, sometimes longer. If it were due to nuclear reactions inside the material then that would not happen. The piezo's are also sensitive, but not nearly as much as diodes, which is not a surprise since piezo are larger than the semiconductor material in diodes.
It is as if there's undiscovered energy of unique behavior that slowly builds up within the material between the intense natural electric field, and this flow of energy is easily disturbed or diffused.
Regards,
Paul Lowrance
continuing my above post, the TED effect is seen in LED's by shining some light on them. Even low levels of light for a few minutes can make the LED's take a *slow* nose dive into becoming disturbed. It is actually fascinating to watch, as the effect is not instantaneous. For example, shine low level light on the LED, place it inside the shield with the electrometer, and observe how the voltage produced by the LED slowly begins to decrease, and more so over time similar to an avalanche effect.
Paul
and still continuing ... some emails I get over the years are interesting about ectoplasm & flow of etheric energy. Look at the similarities so far -->
* One can read books dating back ages ago where the claim is that ectoplasm is sensitive to light! Diodes with transparent casing (e.g., LEDs, & other diodes such as 1N914) are also very sensitive to light.
* It's said that etheric energy flow in crystals *slowly* builds up over time. In diodes & piezos the DC voltage also *slowly* builds up.
* Again, dating back long ago the claims is the ectoplasm is sensitive to physical matter. It's difficult to test this in a diode or piezo, but we can say that the DC voltage produced by such components is sensitive to DC current. The more DC current, the faster the componets ability to produce DC voltage vanishes. The rate it recovers depends how shielded & much it's left alone.
* People who claim to have 6th sense say it's *easier* to produce etheric flow in crystals. Piezos & diodes are made of crystalline molecules. Most diodes are made of monocrystalline & polycrystalline silicon. A common piezo is made of quartz crystal, perovskite crystals. Also some piezos are made from certain types of ceramics and PZT in crystal form.
Sorry if that sounds so far out there, but that's the only close correlation so far.
Regards,
Paul
PaulLowrance
Dark Flow, it’s a new discovery in astronomy, cosmology. Just a year ago they discovered that clusters of galaxies are flowing in directions that should *not* be flowing!
A cluster of galaxies between the constellations of Centaurus and Vela is flowing at 600 km/s (1.3 million mph), and they say this cluster should not be moving.
One has to wonder if whatever is causing such streams of mass to flow in the Universe is the same type of source that’s causing the electrons to flow in highly shielded diodes & piezos.
Maybe dark flow is related to dark energy & dark matter.
Paul
Bob Smith
Paul,
Your reflections on crystals are intriguing. I recall watching a Youtube video a few months ago in which an lcd screen pulled out of an old laptop was used as a kind of solar panel to produce dc electricity.
I was also at a health and wellness fair where pendants and bracelets containing crystalline components were being sold on the premise they absorved harmful EMR (from computers) and produced an abundance of ions to protect the body. I bought a bracelet for 20 bucks, and as long as I wore it, my chronic tennis elbow and carpal tunnel problems were kept at bay.
Bob
