Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
miroslav
wattsup
@miroslav
For the toroid you were not that far away. Please see first and second images below.
About the transistor and capacitor, that is very interesting observation and I would have to look at it more closely to consider. But I will keep it in mind, thank you.
The third image is just to show the three points on the OTPU that touch the table, left leg, back leg and the circuit board. Also to show there is no right leg under the right magnet placement location.
Added:
Since the circuit board is acting as the third leg and it is longer then the two other legs (left leg and back leg) you can see the OTPU is balancing on the longer leg in the last image/animation. Sorry about the animation is not that good.
miroslav
sumermagor
Hi there, i did tonns of research about Tpu And steven mark,
And it came out that Steven may Stealed this technology from other inventors...such as NIKOLA TESLA
ok, it came out for me that most of these conversion devices work on the same principle, all of the MEGS,
But they only look&constructed Differently,
So i have started to look for these things and the puzzple pieces are slowly coming together,
i have read some of the questions and replies from Steven mark on some site,
Jack Durban Said he used a TUNED TANK CIRCUIT,
which consist of an inductor and a capacitor
that is the toroidal core connected with the capacitor to make a tuned resonant circuit
This system is Started By two magnets WHICH ARE RELEASING MAGNETO STATIC ENERGY or its been put there as to act as a reed switch to confuse the people so they cant replicate it
magneto static energy is is Re- and de- magnetizing the magnet so it can release its continous power by changing the poles. but the magnet does not loose its strenght because two systems have been connected together and the energy released is also fed back to the system
Reference: search Arpad Boday on  www.ipexl.com
check this video out as well,
link:   http://www.youtube.com/watch?v=jMq657dgYT4&feature=player_embedded
website:     http://freeenergygroup.com/
now here is a patent from NIKOLA TESLA:
http://www.freepatentsonline.com/0381970.pdf
which is said to be very very very very very very related to TPU :)
i hope we will suceed,  Things do have to change on planet earth,
Love and light to all of you!
sparks
  This was early Tesla.  This is a motionless induction generator.  SM took this concept but instead of using iron which is ferromagnetic he used copper which is nonmagnetic.  Then replace the generator with capacitors but delay the tank onset of the ringing in each tank by whatever electrical degrees creates a rotating magnetic field.  Put a copper winding inside and turn what is normally eddy currents through a lamination stack into usable currents to drive lightbulbs.  The tanks will need to be magnetically resonant with the ability of the ambient magnetic field to act as a restorative force in each tank.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
