Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
forest
when they are removed exactly at the same moment the result is additive ?  ::)
one of SM tips is saying that.... and I think it's true just that :o
giantkiller
Well this is definately very, very cool.
I like the 90 degree winding in Video #7 ;)
The two wrappings with the difference of lack of insulation on one could cause just delay one would need.
Just read this...
wattsup
Quote from: forest on April 07, 2010, 11:39:43 AM
@forest
OK, now I get your question and it is very good. Yes, SM mentioned what would happen if you stop the pulse before it reaches the end of the wire - Tesla style. Removing both ends of the wire at the same time is one thing, but in the open ended scheme, all you need is one side being pulsed because the other side is always open, hence every time the pulse goes off, it is both ends that are off. lol
To stop the pulse before it gets to the end of the wire, the end cannot be connected otherwise there is no end. Exactly as being done in the video.
Very good point. Thanks.
forest
wattsup
how about bias required to create magnetic field ?
if you have in coil which is open from one side  strong magnetic field (DC bias) and you make a pulse from other source and you find a way to abruptly disconnect both sources in the same moment having coil open from both ends then you should expect something extraordinary because energy cannot return to sources
SM said about cold cathode biased by low volts big amps and pulsed by HV low amps, two power sources suddenly looks like one of bigger power on immediate collapse
amps X volts may be not reactive ???? :o I really don't know but be careful ::)
wattsup
@stefan
Who the hell is this turkey brain called @wozlzl. Registered today, made 14 posts all almost the same thing. I suggest you ban him today and break a record. The least amount of days before being banned. lol
