Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
sparks
    Here in Southern Florida it is 90degrees F at 9am.  Imagine taking a propane torch and raising a cubic mile from 89 degrees to 90 degrees.  Yet by 3 oclock 100,000 cubic miles will be heated 5degrees.  That includes all the water latent heat as it changed phase to steam.  Countless atoms are moving colliding accelerating deaccelerating.  Mostly because of infrared frequencies stimulating water.  I dont know how many joules equates into a BTU butwe got plenty of joules round here.  Just the vertical lift of a single cloud is an astounding display of power.  Think of taking a swimming pool and heating it enough to turn it into steam with an oil burner.  Steam that is of low enough density and high enough kinetic energy to go up a stack 5 or 6 hundered feet.  Lots of barrels of oils.  There are nightly lightning events.  My point is that direct thermal to electrical energy without reliance on chemical potential energy has got to be doable.  I really believe that when an atom is ionized the kinetic energy of that atom is transferred to the liberated electron.  As Chef clearly demonstrated ionized atoms and electron movement is controllable by use of an external magnetic field.  Electrons and ionized cores do not move the same way in the presence of a magnetic field.  Tesla would quench  spark gaps by use of magnetism.  If one does the math the binding energy of an electron in an outer valence shell of many elements can be far less than the kinetic energy of the bound electron depending on the temperature of the atom.  All that is needed to convert thermal energy into electrical energy is not the antiquated turbine or piston.  It is the radiation of an ionizing frequency upon matter in motion within the presence of a magnetic field.  The plasma electrons will act as a group or create a force as they will be moving in the same inertial frame.  This creates an electrical monopole of high density.  This moving polarized electrical field is a force field.  It will exert an electrical pressure upon whatever it encounters.    Capacitive coupling a target plate to an antennae that is either focused or coaxial with a receiver is the only way I know of to use electrostatic induction.   I am going to checkout electrostatic speakers more closely because I betya SM did.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sparks
   Just want to add that the energy of the individual electrons is totally dependent on the wavefront of the transmission.
The intensity of the transmission will determine the total number of electrons or what plasma physicists call the heat of the plasma.  It is confusing that they use this term as it refers to the number of ionized atoms in a field compared to the total number of atoms present.  Not related to the kinetic energy of the individual electrons acting as a force.
Think Legacy
Spread the Love
Gobaga
NickZ
  Guys:
   When is a Joule Thief not a Joule Thief?
   Giant 15 pounder +,  that's when...
   http://www.youtube.com/comment_servlet?all_comments=1&v=ksy3TXfDFYo
   If anyone sees a follow up on this video, please post it.
    Thanks,
              NZ
