Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
innovation_station
now what about my 808  ;D ;)
it has 2 freqs 2 phases of 3 channels each of pnp and npn in sync...
it has to phases so it flip flops FOREVER .. :P :)  imagine ...
now apply what i just told you about what im doing on plannet earth right now..
how about 71 species above .. human heads ...  :)
808 is BASIC  THE GOLD RING ... A LIGHT YEAR BEOND ...
btw 12 lower are devided from upper ... so when i give this to you you are contained ...  we know where you all are ..  your graduateing ... in order for this go beond ...  ya better quit fighting ...
why did we re incarnate back here ... i just answered you ...  lower 12 above humans are turned off ... no other way to come back in ...
enjoy your most wonderfull gift ... life ..  live it with love!
thank you ...
i will say this this goes way beond human comprehenction ...
it may be that some harmonics come from the crystal in the diodes...   how ever ...  dont think i had any on those scope shots ...
YOU DO REALIZE RESONANCE ONLY CREATES THE DOOR ... LOL  YOU STILL HAVE TO OPEN AND CLOSE IT ...
y mess around with batteries ...  WHEN THERE UBC'S ULTRA BOOST CAPS ..AKA... ALIEN CAPS...  LOL
well now ya know ...   can you reinstate...  my posting privilages....   ?
anyhow now when  you finally get it ... 0 pattends are gained ...
to my knowalage ... TESLA never built this exact such device ...  so i will call it the IST H.T
I EXPLAIN MY HARMONIC TRANSFORMER DESIGN   and im set to read only ...  hummmmmmm
wattsup
Quote from: stprue on December 01, 2009, 11:01:29 AM
@wattsup
Would this secondary pulse be in the same wire or a overlying wire wound in the same direction but on top of the constant DC wire?
I would say all on the same wire because you do not want to rely on any coupling method. You maintain a major stressor on the wire (that is the DC) on the two turn ring. That ring will permeate a field around it that will cover the outer wound control coil simply because of proximity. Now pulse a degaussing frequency into the same ring that has dc on it so the electrons flip back to normal at on, and swing a kick at off.
So instead of switching the main DC line, you maintain a steady DC line and cause a degauss action on it. The DC line always stayed at full potential and does not need to be switched. By doing so, you cause an action on a bigger potential with a smaller potential at the proper frequency.
An example is if you are trying to push a damaged truck up a hill by pushing it in small increments. You can stay behind the truck and push it in small pushes just enough needed to move it one foot at a time up the hill, but each time, you will have to bring your push source back to zero, wait, then start it again, push the truck up higher, then stop again, etc. Or you can put a steady motive force behind it and hop in the driver cab and simply work the brakes. Each time you let go of the brake, you are again at full motive push force, not having to go from zero onwards.
This is only an attempt to "think out of the box".
stprue
Thank you for dumbing it down for me this makes sence.  This is a very interesting idea and seems easy to test!  Do you have a TPU or something similar to test it on?
wattsup
Quote from: stprue on December 01, 2009, 02:58:01 PM
Well I am at work presently but setting this up is very easy so I will try out the idea and let you guys know more about it. Actually I have several FTPU builds now to test out different ideas.
If @Grumpy was around, he would like to know that I tested a toroid speaker magnet with two coils wound over it during the weekend, as per his suggestion. Nothing conclusive yet but some very interesting buzzing sounds, no coil to coil coupling though. Were the hell is @Grumpy and now @Poynt99. WTF is happening on this forum. Guys with years of membership being banned. Wow, will I be next?
