Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
Qwert
Quote from: bolt on August 09, 2010, 08:26:14 PM
There is NO elite club its about a long standing relationship with people working to achieve the same aims.
By "Elite" I mean those guys who are skilled in their profession of a field. The sign "Elite" appears in their Profile.
I am here just to find a way to prove the truth. Thank you for your kind response. Despite that I find it not very convincing, IMO, you deserve for the "E".
giantkiller
I say build something, lots of things and be master of your pile.
Then when somebody asks you can just reach in and whip something up regardless of cost.
And you will have really cool toys in your pile.
Kidding around? Yes. It gets way too serious with bashing and apologetics.
Qwert
Quote from: Mannix on August 09, 2010, 07:59:59 PM
Whattsup ? the whole universe!
As yes it does revolve around you because you are at the centre of yours.
IMO, based on history of his work, Wattsup deserves better treatment. Even his most recent opinion is based on solid work. Your's not. You try to ridicule him and his work. Did you do some solid job to contradict his? I did not mine but I don't ridicule.
mkt3920
Quote from: bolt on August 01, 2010, 05:48:00 PM
"Tonight, if you discovered a method of producing continuous reactive power output that can be "re-condensed" enough to feed back to the circuit in a loop, and all you need to start it is a small 3vdc lithium computer battery (3LCB), but for all intents and purposes this energy production is not enough to produce any meaningful work but is enough to loop onto itself indefinitely, what would you do? "
You have no idea how close you are but you dismiss what you actually see. You have been taught reactive power is meaningless yet it IS THE GRAND MASTER KEY TO ALL THESE OU DEVICES!
OU becomes from energy transformation while OU = RF as a simile. The TPU is just a huge reactive power generator they are all the same. I don't care if it  a MEG or Kapandze or a TPU or a Joule Thief a Rotoverter 3 phase motor in RV mode.
Electricity is NOT electrons they get moved as a by product.  Its the very reason why volts and amps are able to lead or lag as they travel at different speed due to the mass. Even Don Smith spelled this out very carefully and quoted his devices in KVARS often 10KVARS or 100KVARS devices. Current is a byproduct of waste. Volts are joules potential,  See Newman motor he runs that iron beast on 30 odd volts of PP3 batteries.
Only mA required to move the Newman motor because reactive power translates to intense magnetic flux this the the electrostatic stress transformation. Without this non of these OU devices could exist or even be conceived.
You want proof? Fine take a normal transformer and load the O/p with a large series choke and a cap. Tune the inductor and or cap to create a perfect out of phase condition. The i/p power is almost zero amps apart from some leakage. Now put a 500 Watt lamp in series and the lamp will light. Re-tune the LC to correct for lamp impedance. The 500 watt lamp is now fully lit. THe volts drop accross the bulb is under 12 volts yet this is a 240 volt bulb.
The i/p watts is leakage in practice maybe 3 watts. The bulb is fully lit! HOW??? this experiment done hundreds of times. RE will power the bulb under standing wave condition. A standing wave condition is a Scaler Wave. The bulb work under water and you wont get a shock.  Tuning is a real pig you might have to spend half hour getting tuning perfect even moving  the lamp wire will knock it off tune but it works.
What you are seeing if you do this is Radiant Energy powers the bulb at Zero Point Nodes its the key to all these circuits. All they are doing is creating VARS yes even Bedini is power factor correcting the RE charge going into the battery.
Now at some point SM knew this one only has to read Tesla to understand you only have to create precursor conditions to tap radiant energy. Its no big deal its been done thousands of times. If you think SM would go out of his way and have 12 volt lamps re-stamped with 120 volts or modify lamp holders filled with batteries i'm sorry you wasted so many years and not once found that VARS create OU conditions.
Here is another example. Take a 3 phase motor 5hp motor its normal idle current is 6 amps at 120 volts.= 720 watts! In RV mode that motor will run on about 10 watts. Measure the reactive power. It has 1.5KVAR in circulation. The KVAR circulation is creating one hell of rotating magnetic field from the RE entering and powering the motor. Its NOT running on 10 watts that is the leakage current required to maintain resonance. Like the scaler light bulb its pure RE powering the motor.
The motor runs ICE cold sometimes frost will cover the case due to RE. YES i have seen this myself not ice as some have under critical conditions but covered in condensation and cold to touch.
If you want more examples let me know I  can show many many RE experiments.
http://merlib.org/node/5508
"After my 35 years of experiments with the term "free energy" and "over unity machines". This is what it turns out to be "Reactive power" and that's it."
giantkiller
@mkt3920,
http://merlib.org/node/5508: in reference:
I see it now. The devices that work have a metallic sink somewhere on the device. In a motor this would the windings and the ferrous. In Deyos coil it would the conductors running along the sides. In Don Smith's PVC there is a coil facing charge bar that is positioned at 90 degrees to the coil windings. In the ECD there are conductors running along the sides. My latest pretty coils have a conductor running the circumerference and 90 degrees to the windings. The GK4 had conductors at 90 degrees to the control windings but on the inside. Bedini mentioned a very simple circuit that engineers could not understand.  Jaf Cleer of Biomod stated the same thing.
So what if the simplest thing is a Radiant/RE/Reactive producer having a sink near it. A metal object to absorb the high speed energy. I leave the physics to someone else. I am just trying to show a configuration pattern.
In the rotovertor the ferrous aids the resonant tank operation. And when saturated it then collects the cold energy like a fully charged cap that charges way past its rating with a ghost charge.
In coils the collecting run is connected to caps to hold the charge. Sounds too simple but in the examples posted here the conductivity of the conductor is slower that the impinging charge. This makes me think of a hyper charge carrier.
