Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
wattsup
This is what I have been saying about the relation between the blotch wall in the primary and the ring polarity.
The ring is getting the negative of the primary and the negative of the pulse generate, so the ring, for all intents and purposes is negative. But then where is the rings blotch wall. It is inside the primary. lol
This is what I am trying to explain of the required imbalance. If the ring does not have a blotch wall, it can only have one polarity. By using the primary blotch, this makes the ring one polarity, not two.
Now I will try it with two rings and two control coils. It will simply use the same set-up but separate the two primary negatives, one to each ring and then they come together to the negative of the pulse generator. Then on the secondary of the toroid, each coil will go through its own or opposite control coil then go to the output cap.
More fun to come.........
wattsup
OK, so here is a question for the EE guys cause I don't have the know how to calculate this or make a good circuit.
My toroid primaries are .3 ohm each. How can I take a 1.5 volts dc battery and have it pulse 10% duty at 90khz. That will be my starting point for getting this to start without a pulse generator.
Can someone please please please draw me a 3-4 component (not more) circuit with values, Thanks in advance.
sparks
   Love the geometry of those coils.  Torroids making mushroom clouds.  Merry xmas.
The wavelengths are synchronizing here on ou at least for me.  Angry scientist just put up this picture in the Tesla Tech topic   The other one is a little magnetic reconnect avatar of another board member.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
That is why I posted this vid... Same thing you explained.
http://www.youtube.com/watch?v=0C1uicaW7Ms
And there are other vids from last summer with same thing. I put in 43k and -6mhz out.
Quote from: wattsup on December 23, 2009, 11:25:10 PM
Also, trying to find a way to make the scope stay put so I can take a photo but it is very difficult. The frequency changes like a never ending wave shift slowly one way. As I catch it, it changes again.
This is crazy because the speed of pulsing is sooooo high now, much higher then the 90k pulse frequency and it shifts so I cannot catch it as a stable scope shot. Weird.
wattsup
PS: The universal knowledge fills you all.
nitinnun
has anyone tried to use sound,
as the source of high frequency,
instead of using electricity,
as the source of high frequency ?
sound is likely easier to create,
than electricity.
if a materials natural properties,
produce the high frequency sound,
than wouldn't that be profoundly easy and simple ?
