Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
BEP
Quote from: bw on December 01, 2009, 09:52:43 AM
GK you said your nst has output of 35mA, isn't that .035a x 6000v = 210. watts out?  I bet the input is less than 210 watts.  Here's a photo of one that is about 50% overunity right out of the box, zoom to read tag.  http://www.brightneonsigns.com/enlarge.html?http://ep.yimg.com/ca/I/yhst-31811652982121_2077_60476857
Maybe I'm missing something.
Careful folks. It is common for high voltage output devices to have labels that seem to add up to OU.
It is Over Marketing (OM) not OU. The output rating is for part of the time for a single pulse, not continuous. Shoot, if it were true I would be powering my whole neighborhood right now. I have several HV generators from clean-room devices. They even have 16 ga. solid wire for the output coil.
Their output rating is 8kV @ 30A  and the input adds up to a couple of hundred Watts. No OU there. In fact, they are only about 60% efficient.
Watts are not Watt-Hours  ;)
sparks
@bep
    I dont think the majic is just in the hv hf exciter or catalyzing event.  For all we know Tesla was burning air and pumping up resonant circuits to very high currents wih plasma currents due to the catlyzing  ionization event in the gap.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
BEP
Quote from: sparks on December 01, 2009, 09:28:41 PM
@bep
@Sparks
I think I've told you this before:
It scares me when I understand your post AND believe it possible  :D
forest
Forget about gap. Tesla used it only at start. The power is in resonance harmonics because they are sucking energy from Earth.So if you have resonance and learned how to get power from it without stopping it you will have the same amount of amps per volts.
giantkiller
Is that amps per volts from the Earth system or the starting circuit?
Quote from: forest on December 02, 2009, 04:25:45 AM
