Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
Grumpy
Quote from: giantkiller on October 30, 2009, 12:48:10 PM
Don Smith's device 6-1 Layout and schematic.
--gk.
I have been told that two bucking coils can create the shock wave zone between them.  Always thought that a pancake coil would be a good collector for this configuration.  You could put several in a ring configuration.
        -Frank Edwards
innovation_station
GK THAT IS NOT THE CRONOVIZER ....
that is the teleporter ...
and it propagats the engery feild between 2 contact points ...
i for some reason see it as a pancake style unit ..  and they looked like audio speekers ...
perhaps the cadusious cone coil  ;)
excited by the 3 on eather side ..
none the less it is speculation and intution with me ...
i think if spun fast enough you will spinn a hole ... and this hole will manipulate space time .. and if done with in a working range ..  human dna life and non metalic things can pass through .. this tells us it is not such a high freq device .. because strange occourences may take place .. and the only thing ANDY says is that a nickel in a fellow jumpers pocket got excited from the feild in a jump ...  much to the effect of a microwave and metal   sparks hot that kind of thing ..
ist
the dwg dont feel right bro ..
btw 6 fits in 8  ;)
wate a min....  at closer examination at the moon fountian .....  LOL
never mind ...   just drop the boxes ...  lol   and im starting to think 1 wire ...
DreamThinkBuild
Hi Giantkiller,
I believe you are on the right trail. I've been looking into high speed flux disruption. Every single patent that deals with high voltage/ high current potential snaps the flux lines at high speed. What I believe is going on with these TPU's is that there is way to create a virtual high speed spinning/flipping bloch wall. By virtual I mean it appears to be spinning/flipping without mechanical force only setup through secondary waves/control coils. Think of a resonant domino effect that cascades itself throughout each coil which changes the alignment of the bloch wall. Create a "high speed" spinning, collapsing or expanding bloch wall with enough flux disruption with minimal saturation/impedance and you'll get the power you need.
Here are a couple interesting patents I ran across:
Never mind the 5.54MegaAmp output, the windings are whats interesting. http://www.google.com/patents/about?id=s0siAAAAEBAJ&dq=4935708
This line in particular from above: "...First, a magnetic flux distribution is established in the generator using excitation field windings and armature windings. Second, that magnetic flux is "compressed" or modified in selected areas creating a customized magnetic flux pattern which will induce an electromotive force in the armature windings..."
Another where the windings are shifted.
http://www.google.com/patents/about?id=nswRAAAAEBAJ&dq=6720698
Another:
http://www.google.com/patents/about?id=plsdAAAAEBAJ&dq=5210452
If your looking for a high power pulser here's one, could snap the flux out of your coils though :) :
http://www.google.com/patents/about?id=ccgkAAAAEBAJ&dq=5434456
giantkiller
As the Flux cutter is pulsed opposing the primaries and exists in the gap between the primaries that are in series there would occur 2 bucking joints, one on each side of the flux cutter. That would be a good place to arrange the pancakes parallel to the coil tube around the bucking area. That way the pancakes look like the multi receiver configuration of Tesla's wireless.
Quote from: Grumpy on October 30, 2009, 01:32:18 PM
giantkiller
I go the names mixed up.
I did run across a coil diagram. Here I redrew it.
All of Smith's coils are air core. Muy importante! This keeps the effect in space and not locked inside something.
Quote from: innovation_station on October 30, 2009, 02:03:26 PM
ist
btw 6 fits in 8  ;)
