Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
bw
Isn't 9 the bloch wall itself in Rodin's math?
It's been more than a year since I learned his math, maybe I need to re-watch.
From what I remember 3 & 6 oscillate with 9 at the center.  that is one system.
the other system(circuit) is 124 and 875.
I think that was the doubling circuit or system.   I gotta review.
I do remember if you could stand on any number on his coil or graph that you
have a repeating circuit or set of numbers in any direction you point.
Nature fits this same pattern
I understand best by comparing dissimilar things.  Diode=check valve etc.
consider this.  if you pull a vacuum in a large tank at sea level then open
the valve to ambient what happens?  Air rushes into the tank with huge force
until the ambient pressure is the same inside and outside the tank.  Works in
reverse too.  Put pressure in tank then open valve.   It will always return to
ambient.   This is how our tank circuits should work.  Don says it takes very little
to disturb ambient and what you disturb will always return to ambient with force.
It's easy to disturb like the tiny push needed to keep a swing or pendulum going
when you match it's frequency.   The weight of the swing does the work of pulling
the vacuum or pumping the pressure into the tank.  The faster the better.
There you have it.  Bloch wall= 9
I just wish I knew more electronics.
innovation_station
9 is RECONNECT...
3 will be 1 spin 6 the other ...
do do do  3.<.> 6..  do do do ......  ....  (.)9
devide spin and reconnect...
ist!
rodins ... colours  freqs....   carriers? lol
so in short wind up to resonance of object ...  and COLPASE THE WAVE ... object ends up at 9 ON RECONNECT...  : )  basically you want to de spinn something ... and draw pos to 1 side and neg to other ...  and re join it ... through mass to mass resonance ... of 3 and 6 on 9 ...
anyhow ...  i have WAYS FAR IN ADVANCE OF THIS ONE ...  ; ) includeing transmitting and recieving via sclar .. back to electro magnetic .. i dont see why it wont work ...  egyptian toys ... operate very similar ... lol
thank you!
giantkiller
Yes,
9 is the Bloch wall.
Think about this: When we see a tornado we only see the matter swirling around. But the spin is magnetic. Same below as above. So what is flowing throught the center to match up with Rodin's recirculating model? In this sentence the ground level is the Bloch wall or just above 0 in Rodin's model. In the 2 liter bottle tornado the air flows up through the center. Same as Schauberger vortex.
That is why the Rodin appeared here. I am still pursuing the Bloch wall model.
Had to clear off the bench to make room for the next cluster of builds coming on board. Plus I am adding modules to previous builds.
Let me explain my bench. I get an idea or see a specification then jump on it. It has to produce something or proof. Then I am onto another. I don't spend alot of time trying to produce OU. Seems people try to beat a dead horse with possibilities or make a small idea blossom into 'The Answer'. There are enough tests out there to piggyback off of without duplication. I extract the nuggets and throw out the trash. This beast is ellusive and made of many specifications. The Rodin coil has cetain tangible aspects to it that pertain acrosss the board for this pursuit. It is the electronic version of Schauberger and this IS a big deal. But alas one part. Rodin mentions 3,6,9 same as Keely and this IS a big deal. Rodin mentions musical notes, chords and harmonics same as Keely and this IS a big deal. He mentions the Poynting vectors and their specific alignment same as Don Smith and this IS a big deal. He mentiones the storage in the gap / ghost winding just like Don Smith and this IS a big deal. He mentions the missing energy field in the third winding of the DNA just like the artifact that Dotto and Rife were chasing and this IS a big deal. He mentions the matrix map and photonic value of the created field just like the photonic camoflague suit in the movie 'Predator' and this IS a big deal.
In essence the phrase I coined: 'Frequency equals Matter' and this IS a big deal. Not matter what size system one looks at this field is there. Matter is the interference of frequencies same as photon production just pick your frequency level.
--Giantkiller.
wattsup
Quote from: giantkiller on December 09, 2009, 02:06:48 PM
--Giantkiller.
Yes, yes and again yes. That is how I am doing also. Find the effects then worry about putting them all together but I concentrate on the SM TPU's. It's a challenge thing. Effects, observation, logical deduction and process of elimination. Oh, and no fear to be wrong and no need to be always right makes you good to change direction when required after more elements of the puzzle are in hand. There is no other way. lol
innovation_station
i like to be worng ..   this way we get the true answer when we do fianlly find it .. and discover it is only the answer to more and more .. and the more we as a human race move forward in time our ansewers come from deeper and deeper back in time till we finally get the correct true understanding .. and as we journy this path the cosmos is designed to aid this process through your shock ya's lol as the planet hits a resonant point or harmonic  so do you ....  know what i mean ... ?
i dont need to know all just know enough where to look for more as i find myself in need of more ..
if that makes sence ...  we are all in this life this time around .. to over come the last things needed to graduate to the next level this will come no matter what this is nature ...
some are awake early ...  wonder where they stand...
