Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
bw
You almost have to see much of the video to get it but like gk said 4+ hours and worth it.
I'm sorry if I mentioned something I shouldn't but like gk says there are similarities in this and
Don's generators and the work of many many others.  I thought it may be helpful, that's all.
bw
Forest,  you asked how six ties in with three and nine.  this is the "flux circuit"  3 and 6 oscillate
back and fourth, one plus the other always equals nine, they both hinge on nine, it is at the center
piviot or "bloch wall"
forest
Ok,I have troubles with Bloch wall understanding but last day I realized that Tesla might thought about these numbers because of it's "construction".
3 - it is center tap coil probably or maybe a bloch wall
6 - it i  coil in one direction (for me it's right wound)
9 - it is coil in opposite direction (for me it's left wound)
folow actual writing of these numbers
Looks like Don Smith is right and I think we are talking about the same.
bw
I'll tell what I have found hoping this helps lead to the answer.
I think I may see where power may be captured.  I have wound
two identical air coils using one strand of house wiring.  I use
a capacitor made of a sheet of bronze (couldn't find copper local),
a sheet of aluminum, and a sheet of plastic between.  I have two
spark gaps, one spark plug and a jacobs ladder made of welding rod.
I position the coils at right angle to capacitor plates.  Then I connect
one wire my nst to one end of one coil.  To the other end of that coil,
I connect a jumper wire to one side of my capacitor.  I run another jumper
wire from that same side to my jacobs ladder gap.  To the other side of
the gap I connect the second wire of my nst.
Now for the coil on the other side of my capacitor.
I connect one wire from the end of the coil to the unused plate on my
capacitor.  From the other end of that same coil I connect a jumper to my
other spark gap(old spark plug).  To the other end of the spark plug is connected
to an earth ground.
Here's what I get with this setup.  My nst runs a good steady spark on jacobs
ladder then "bam"  I get very strong spark on my spark plug and my nst stops
at the same time.  I feel like this spark is the real power.   I guess I need a diode or
something to keep back current or whatever it is from killing my nst.  it restarts
after shutting down when i restart it.
giantkiller
@bw,
I have used a neon from a flourescent starter. I get small spikes on the scope. I put in an open gap or just 2 wires and the spikes got larger.
--Giantkiller.
