Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
sparks
   @Otto
    GK once said a most interesting thing.  He saw the tpu as a large spark gap.   I have a hard time with the tpu exact construction and theory of operation.  I do know that Tesla created electomagnetic resonant circuits using bifilar wound pancake coils.  The resonant circuit in the all in one packaged bifiilar wound energy capacitor not a charge storage device an Energy saver upper.
I do not know the effect of two such energy capacitors resonat at the same frequency but exited at slightly different times or phase offset by nanoseconds residing within each others mutual capacitance and inductive fields of influence.  It may have been Marco who provided an oscilliscope shot of a couple of torroidal coils ringing and the remarkable thing was that the relative bias between the two ringers was changing. Floating up and down the oscope.  Well anyway I did my little overunity experiment a number of years ago and it produced too strong a reaction in the ambient field for me.
Marco knows what I'm talking about once it starts happening it is real hard to stop.  I dont even dare replicate my own experiment at this point.  SM said this is not for beginners and he sure as shit spoke the truth at that point.
    Peace Love and Prosperity to all.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
@sparks,
Yes, I remember saying that. And maybe at the time I did not finish my thought. I felt my answer might not have any weight or be too far out there in the incorrect terms. I know most people had problems following me. As the energy goes around the coils the layers or plates it discharges electrostaticly. This firing at the wattage levels of the TPU would create a thumping via one way direction of operation with the magnetic connection and disconnection. I also saw that the breaking of the flux was not the energy producer but that happens during the reconnect and that would happen on the other side of the wire. All of this activity would be on one side of the wire which would create a condensed magnetic field. Since the BEMF is larger than the FEMF we have our answer right there. There would be a larger force or effect on one side of the coils as they sit in a ring. Smith's PVC jogs back and forth. This effort is now seen by the Earth's field which also collapses on to the coils. The BEMF is both things. So the resistance of moving the TPU around while in operation is really the point of connection with the Earth's field. Like Bolt said 'A virtual iron molecule' and not by an iron core but by the magnetic field created. Not by the freedom of movement, the release or skipping. Just depends on the interpreter's point of view because the language actually explains both sides. So the resistance looks the like start of gravity control. A minute effect of electrogravitics. TTBrown's tests were very close in parameter types to the TPU. There were just too many 'Oh Wow!' moments to stop and get explanations straight. Same event as if one would see the Holy Grail the first time and knowing what it is. Like a constant dream come true with no chance to catch one's breath. The comment in the latest Indiana Jones movie was 'The space between the spaces'.
I hope this clarifies some things.
And your explanations have been very helpful too.
Quote from: sparks on December 24, 2009, 10:00:31 AM
   @Otto
giantkiller
Smith stated the electron spin direction creates either volts or amps from their respective secondary ends.
Put either 2, 3, 4, or greater combination in series placed in a circle on 1 secondary and you get to make wattage at the intersecting points between the primaries.
giantkiller
Thought I would reinterate from someone who definately helped me out.
The explanation is impecable...
Quote from: bolt on August 31, 2009, 02:19:59 PM
its a while since a looked at the TPU but i always maintained that coil banging with pulses, and logic control is wrong!
In the past few months/years many many more RE/OU devices are shown on the net and they all have common themes. SM said the answer lay with Tesla and he is right. Its only a case of resonance and self oscillation. Again SM emphasized there is no mass control circuits and in fact no more then self running oscillators.
What i do know based on the work of Tesla and Don Smith is that RE = RF in a node of time space and magnetic coupling does not suffer entropy loss and this is the KEY!
In order to make RE you must first excite the local ambient space. Anything over 100Khz enters the RF arena and split EM can occur.
Take HV coil transformer as used in strobe supply it will give 5Kv if we drive with  5Khz clock using a 12 volt source battery.  If i couple this through a balun driver i can match this into a collector loop of 5 turns.
if i take this  collector loop i get this to self oscillate at say 1 meg with a 2,200pf cap and the result will be around 1 meg that contains 5Khz modulation.
If this coil is loaded in anyway i will kill the source! if i rectify this i end up with DC 5000 volts with 5Khz hash as modulation, so far so good. EACH turn on the collector now has 5000/5 turns = 1000 volts. But i don't touch this source and this is unlike what everyone does on this forum is play with the source you must NOT touch this!
Now make another collector of 1 full turn. Its LC =F will be quite a bit higher then the primary driver the ratio needs to be 1.618 higher so 1.618 megs.   In open air non cored magnetic coupled to the source this loop will acquire 1000 volts. Remember SM explained all this in his notes.
This secondary collector will acquire magnetic non loss induction to the primary driver. Its o/p tank is fed to a FWBR and will be 1000 volts and the current is limited ONLY by the wire resistance.
Again if i want more current i add another collector and it COPIES from the source! SM explains all this again in his notes. If i want more volts i add this collector in series to give 2000 volt supply.
SO
What are the magic frequencies? There are NONE!!! only magnetic induction is 1.618 higher then source F
1  Clock driver to start HV
2 Driver RE energizer collector F = diameter of L plus C
3 collector load = F = diameter of L plus C and is tuned to 1st collector for best results look for 1.618 higher then source.
O/p = turns ratio of collector 1 to collector 2 into FWBR = DC PLUS source modulation = 5Khz 1000 VDC
Sounds too simple then read Tesla patents, read everything about Don Smith and Kapanadze the latter has several working systems using RF magnetic induction devices.
Can i build this using parts from Rat Shack? YES Is it simple like SM said? YES and does it work like Tesla as SM suggested? YES Does it rely on resonance? YES and of simple low cost circuits no complex mosfet coil bangers? YES
The minimum number of collector coils required is 2 one source one copy. But i can have one source and 5 copies each copy becomes a NEW supply of FULL capacity.
Don't forget RE = RF in energy transformation!
--giantkiller
stprue
Thats very interesting GK.  How is your Don coil replication coming along?
