Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
I had a time expenditure in a SNAFU.
Had a power outage(Not by me but a storm) which took out my main station's wifi dongle. My Macfee choked and Sality virus took off. My station had repeatedly crashed before this incident. Had Zonelabs, got rid of that, had McAfee and got rid of that, downloaded Avasta, it found the Sality virus in a number of locations still on my harddrive and some down in the system root. Deleted the files, repaired the OS, bought a new wifi, now need to configure the pc to get access out to the net. I keep getting 'Aquiring network address'. This a configuration change I will alter. Main station runs much faster now. I am going to stick with Avasta.
Have gone back into my library stack of OU prints. A good habit to get into which reveals prior insight.
@stprue
To answer your question I have a setup which blew my amp meter fuse but the meter still showed a display of zero and the voltmeter worked. I took out the meter. I placed variable capacitors in circuit to adjust tuning. Did not see anything. Something on my list is the Opamp buffer from the xr2206 Keely controller to drive a circuit.
I did have the results Bolt metioned above a number of times where you put in a lower Khz frequency and get Mhz as a coil reading. Once 'tuned' is achieved it seems the the magnetic field is static at the RMS value and further out it is dynamic, what would appear as a waveforrm on top of a DC. You saw that in your 2 coil experiment where you had no inductive coupling when the two coils touched. The B field has latency after the E potential equals no light lit. This explains the height in the TPUs. My thinking tells me that when one drives a coil with HV and low current that this is a different operation than a low voltage like 12-36 with current. The later means some tuning. My suspicion says the former is what Bolt is explaining and that Smith has entered into the description. If we tune at low voltages that would not be a precursor for operating at the high voltages. This is what I am heading towards.
Christmas is not the best bench time either.
stprue
Thank you for the insite...I agree with it all!  I have been thinking about TPU height and resonance and induction as key aspects to be examining for any sort of sucessful TPU operation.  I also like the direction Em has taken with his coils but I can't tune like he can...yet!  One of my goals is to power a cfl driver with one of my coils inductively but I want to tune either the cfl driver to the coil or the coil to the cfl freq!
wattsup
Quote from: giantkiller on December 29, 2009, 12:42:32 PM
Ho Ho Ho....... How right you are....
@GK
Yes, thanks for putting that post up again.
I will be able to test this soon once I add my second ring, I just need to do some tests with the second ring isolated from the first and the toroid. The high voltage pulsing is not a problem either.
sparks
   Checkout the Aharonov-Bohm effect.  There is what they call electromagnetic potential or A potential.  It is not positive or negative or north or south potential it is the whole deal relative to the rest of stuff.  Most times a description immediately uses the language of mathmatics.  Basically two guys working on Solutions to Einsteins equations predicted this effect pretty much simultaneously.  A particle (or wave) is relavent to the space in which an electromagnetic fluctuation or oscillation is occuring WITHOUT being in the electrical or magnetic field of that part of space.   That means two standing waves seperated by spacetime are effecting each other due to the difference in their electromagnetic oscillations.  The vacuum spacetime grid aether or whatever you want to call it conducts this ema information or potential difference.  To me this basically says the aether is a gravity conductor.  The polarity of gravity is determined by the density of standing waves aka photons.  So BOLTS is right.  Leave the main tank alone.  It creates a gravity pole.  If a vacuum is an extremely good conductor of gravity mass is a great resistor of gravity.  Causes alot of gravity collisions and heating effects coronal discharges light traveling waves strong and weak forces all sorts of radiant events as gravity information gets chaotic.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
