Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
ramset
GK
When I was a kid I would read the life story[up to that time] of Chuck Yaeger
The SOUND barrier, one of the brave souls that strapped himself to a bomb[very big rocket] and was dropped out of a converted bomber[ just like a bomb would be] while every one else stood by and watched.
Those in the "know" at the time predicted DOOM!!
Faster then sound are you NUTS etc. etc.....
So Chuck threw the switches that lit the fuses that blew him past that barrier
A resounding BOOOOM was heard on the ground,
surely this was the end for this madman , thoughts of horror raced in the minds of the men on the ground, such a big sound
With the cocpit shaking like a cement mixer, suddenly all was quiet
Chuck had just made History!!
GK, you remind me of this guy.
Somethings you do alone.
Thanks for all you do brother
Chet
Thanks Grandma
giantkiller
I say 'Thank you', to everyone, great and small and there are those who keep me on track.  :)
I missed JDO300, Motorcoach, Dansway, EMDevices, Bruce_tpu, Yucca, Gotoluc, JoeDirt, Sparks, Forest, Loner, Ramset, Earl, Bibhas De, JLNaudin, and Wattsup earlier. Everybody is important. Aint' this adventure great?
Had to go back over my library to recoup my thoughts and find another angle. There are so many things that fit together that is gets overwhelming. But in this late date it is a positive effect. So for those who are just starting out or daunted by the 'Too much' then 'Be still', 'Press on', 'Keep one hand in your pocket', 'Let no one tell you "No"' and 'Keep your head down'. You'll will get to a point where when you go back over your library you will see vast universes open up that you didn't see before. It is called the 'Truth'.
So,
Now that I have my PC fixed I am back on the HV / variable frequency supply. Instead of plugging the variactor in the wall I am going to drive the 120vac plug with my Keely controller through a fet driver. This type of setup to purchase can be quite expensive. The Keely controller was USD50, the variac was USD80 and the MOT was USD18. If I need more voltage I can add a microwave xfmr. I will post the setup and specs. Goal is potential and not conduction. We want purple streamers(potential) not white or yellow streamers (current). Higher voltage into smaller gauge wire. So a fet driving a coil is the supply and not the final result. The added stages create the HV(high volage) / LA(low amps) which is what the Neon Sign Transformers(NST) do but I'll have variable frequency from 1hz to 1Mhz. I will show the bandwith of operation at each stage. Naturally the limit of the variac will not help the MOT if the MOT has greater bandwidth. Wii will see. Any part of the sine wave that is not true will represent injected harmonics downstream. This may or may not be a bad thing. I got to have a clear goal or it doesn't make sense to start anything. That was Tesla's rule. Run through it in your mind a thousand times till it is perfected then put it in your hands. This power supply sits on a 2' by 2' board on a cart and is totally open. It is dangerous! Hooked up to this I have cheap meters, a portable isolated Oscope with 1000v probes. I am thinking of making a lid with a kill switch for this PW. I have 'thoughts of horror' too.
--Giantkiller. There are no challenges only opportunities.
Quote from: ramset on December 31, 2009, 11:10:12 AM
GK
Chet
bw
GK you are right when you say
p.s. Everybody do this and keep your head down. Pass it along, pay it forward. The only way anyone could not do this is if they haven't read this post. Then they get a big 'DUH' in their Christmas stocking along with a lump of coal.
The clues Don and others left really are enough if we can see past our brainwashing.
Beware big caps like Don uses have the same power of a 44 Magnum caliber bullet, use extreme caution please.
bw
h2ocommuter
I finally moved the most important tools of my shop.
I started building my cart with remains of my hydroxy setup: It has a 2 1/2 HP electric motor powering a 130 amp alternator. this should give me plenty of valadation when I fire the completed system up. A new table top, mounted the plasma globe, the Inverter is placed with a cigerette liter incert. "inverter 12V 300 watt: There is a place for a car battery, a hardwired cord for normal 120 house supply, with an on off switch. and three recepticals. I started building the micro adj, for the 12 plug spark gap; Nicola tesla stated using multiple gaps increases voltage, he showes them in parralell. I have a grounding rod and circuit breaker panel to wire up soon. I tried an alluminum grounding plate but it would not stop the impulses enough to activate the rudimantary attempt of grounding.
Happy New Year!
Thank you all for contributing, This boosts my spirits and sharpens skills.
as we all pull in the same direction take caution and be patient as you go.
"Adopt the vurtue of nature, her secret is patients".
h2ocommuter.
agentgates
