Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
sparks
   Tesla would make sure the generators were running in resonance also.  Using the inductance of the generator coils and capacitance of the distribution system adjusted so the mutual inductance of the generators and primary coil matched the total capacitance of both the distribution system and the in plant capacitor.  Resonance is a storage thing.
I like using the sustain pedal when I play the piano. The hammer falls on the strings and they vibrate for a long time. Unless you damp them.  Tesla would have to damp his to get some attention when folks went to his lightning shows.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
Telsa also injected a virus into his systems.
60hz is mind numbing. He controlled the delivery of his design. He gave the stupid what they wanted. 60hz.
Think about it. Most of us here know that you  don't need to move electrons. Resonance creates a kinetic ringing powerhouse of untold cold energy. Why is it cold? Because the kinetics don't hit resistance.
The world system is based on resistance not resonance. Ha,Ha,ha!
Resistance is a normal facet of what stupidity is always addicted to. And to add to that they even argue about what is right about their wrongs.
Flatlanders...
--gk. 3 more years to go.
sparks
    60hz was chosen because of the bearing probelms with the mechanical dinosaurs.   Tesla knew he could use the alternators for just exciter power but Westinghouse had too much invested into the mess we have today.  Tesla knew he could put the whole transmission system into resonance without load dampening.  He even designed a coil to get beyond the use of capacitors and a transformer that worked like a dcdynamo for the cities that needed dc because of Edison's foolishness.  All shelved because of shortsighted financial concerns.  Then when he came out with planet ringer he really needed to go.  Then he figures out how to magnify the input into a sparkgap from just plain old air mass and now he is really a problem. If the r in an rlc tank is the load and for every input the tank resonates that's a good thing.  If the L or C is the load that is even better.
Think Legacy
Spread the Love
giantkiller
Be sure your battery supply is connected with wires that equal a 1/4 wavelength of the chosen frequency of oscillation. The DC supply creates a DC bias on the supply lines. The resonance of the circuit produces shockwaves on that DC field which creates an AC charge pump which recharges the battery. Much like the Bedini circuit.
The conductor passes DC and the external field feedbacks the AC percussions.
--gk
bw
Hi GK, I have been trying to get power from Don Smith's devices for a couple years now.  I can't quit but have only got small sparks between L2 and ground.  I bought his books and DVD's and replicated the plasma globe and the NST powered unit.  I get no real amps but volts are all over my workshop.  Every wire on the device will make a neon test lamp glow bright when held near.   I just found this thread and will apply what you try to clarify here on my devices.  Thank you for your work here.  I was so caught up in Don's devices that I tried to arrange a visit with him in Texas to learn all I could but he must have had his stroke just before that time, I got no responses.  I just know his units will work, they are in balance with nature.
