Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
e2matrix
Regarding copper oxide, normally copper in wire will oxidize when exposed to air overtime and develops a thin coat of copper oxide.  There are other ways to make copper oxide and are 2 varieties both of which can be a type of semiconductor.  Not sure if this is relevant in the TPU but just mentioning it as otto brought this up.
  Has anyone asked Stefan about those missing posts?  I didn't see them or I'd ask.  Curious minds want to know  :D
giantkiller
@Otto,
Are you saying is it good to 'have oxidation'? I have another set of specs that say 'no oxidation'. Things would change operationally as the material changes.
wattsup
@otto
So basically what you are saying is that if you have three frequencies in the same wire, the highest frequency will be more concentrated on the outer portion of the wire, the medium frequency will be moving from the core to the outside while the lower frequency will be more in the core of the wire. That is a very interesting concept indeed. But if using only high frequency, do you think it is better with single or multi stranded wire.
otto
Hello all,
@GK
yes its good to have oxidation but in a coated wire we have this oxidation in the structure of the wire. Its like a layer between the copper and the tin or silver or another metal. The point is that copperwas heated and then it was coated with a metal.
@wattsup
I can see 2 different kicks in 1wire: one is a very fast kick that is almost perfect(fast ON and OFF pulses) and the other kick is a fast ON but slowly OFF kick. Of course the wire pulsed with 2 frequencies.One with say 200kHz and the other maybe 30kHz. Or to say it better I use 2 different frequencies.
And your post in the other thread about AC: yes, I love AC from DC kicks in my coils.
The last 3 weeks of my vacation I made a few new oscillators and ....hmmmm the results are....what to say, I have lighted a bulb to almost full light with only 1 frequency using only a 555 that a lot of people "hates". Of course around the 555 are caps to get square waves.
It seems that the oscillators are more important then we could imagine. Especially the OUTPUT of the oscillators.
Otto
NickZ
  @Otto:
    Good to see you back.  I was very glad to hear that you're able to light the bulb with just ONE frequency. I also feel the ocilator can be a big part of it, and was many times mentioned by people like Tesla.
    SM did mention two observations about his units:
   slight vibration, and giroscopic effect.
   Since he didn't use a SG, and has repetedly said NO batteries, I would assume that the slight vibration can possibly be caused by magnet chatter next to the coils, and Second, that the giroscoping effect felt may be caused by the unit's feedback ocilating onto itself, and thus creating that giro-like sensation.
  My question to you is:  could the SOUND of his device be analyzed with a scope, and its running frequencie(s) found out by using that method?  This is what is done when studing the sounds produced by UFOs.  Which to me do sound somewhat similar to those made by these magnetic devices. And when those recorded sounds from the UFOs are put on a scope it was found that as many a 8 different spikes can be noticed.
  As I listen to the sounds made my his devices in his videos, it appears to me like there are two waves (or more) ocilatiing very similar to the sound of feed-back in a normal amp when the volume is turned up to far. Not on - off, but back and forth.
   I am as interested as anyone in resolving the mistery of a working magnetic device, and SM had one of the few if not the only real examples known and shown, so far, that uses no outside source.  My only intension is to help in this cause.
  Best wishes to all,
                             Nick
