Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
NickZ
  Gk :
  I just found this video made by Lidmotor from the Energetic Forum, on his Big JT:
  http://www.youtube.com/watch?gl=CA&hl=en&v=maRF1nw0J2Q
  I would think it that it could still be upscaled alot though, by 10X or more.
  I didn't know that there was a somewhat similar idea,  as to what I had mentioned the other day.
  Interesting to see  Lidmotor's version of 12v batteries, an ingition coil, and a tirfilar coil to make the bigger JT, with a charger circuit.
   Would be interesting to see something like that circuit hooked up to a St.Clair coil with a secondary, instead, or like the one you are working on now.
  Can't wait to see what happens next.
Mk1
Quote from: NickZ on June 12, 2010, 07:36:42 AM
  Guys:  Sorry about my spelling, just waking up, or I should I say did not sleep at all.  Will post again, later. It's 5 am here.
        NZ
http://www.youtube.com/watch?v=5WgjobZcAeA&feature=channel
Same here , this stuff is really scary , i could not sleep either yesterday...
Chamlin may be in fact played , this time , but now the 4000 UN trucks , and possible evacuation of the southern states make sense .
Mark
e2matrix
Quote from: forest on June 11, 2010, 03:39:02 PM
otto,
I have old impulse generator from 1975, heavy one which has additional ground cable. Do you think it may work well when not grounded ?
If it plugs into the wall then it will be grounded at least in the U.S. and I presume most countries have one side of the outlet at the same potential as ground.  In the U.S. the ground and the neutral are tied together so I am sure this will not work in the way that has been suggested.  You need to run from batteries although I have some cheap low power inverters that are enough to run a signal generator or two.  I may try that if I can't get find my 555's to build a cicuit.
giantkiller
Current build: Rodin coil wind with associated fields.
giantkiller
