Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
NickZ
     @ Otto and All:
      Well, I see.  Thank you for your reply.
The reason that I wonder how you were coming along is that sometimes the Germans, Russian, Yugoslaves, etz... have a different idea compared to the current thought on electric theory, and can and do come up with solutions that can work out, even if they do go contrary to current principles.
I can somewhat relate to both sides of things as my father was from Yugoslavia, and my name is also Nikola, as was my Grandfathers name, just like Tesla.  But no, I'm no genious,  sorry.  But, my father although a scientist, had always played with radios, electronics, scopes, and instruments of all types.  He would charge big huge capacitors just to show me what they could do when quickly shorted out. So, those kinds of things stayed with me, even now.
   There are a couple of things that I have noticed:
   First,  that if the pulse that is being sent to the coils is a positive voltage and frequency, it will be mirrored back off the earths pulse and come back and produce a negative spike, as can be seen by the meter going to the - side for a second. So, my thought is how to produce a negative pulse, so that the contrary reactive pulse will be a  positive spike instead.
  Second, it looks as if all the SM working units have a shift is polarity, not just on/off pulses. The 2m2222, 2n3055, 2n3904 transistors, or 555 switching may not provide for this polarity shift by themselves, as they are basically only switches, but instead it may need to be done by the reversal in the field caused by or at the coil(s) polarity themselves. I feel that this quick and constant reversal is the trick or key, as that is what is causing the disruptance in the equilibrium of the medium and thus drawing in of the Aether to compensate for the vacume or presure change. Or else, where is the added power coming from?  So, maybe a system does not need to be an OPEN circuit to work, but needs to provide for that kind of switching in polarities. Like an Aether diode, or Aether pump.  It may be possible to do the same effect without the switching in polarities, but that may be why no real positive charge is obtained from the applied pulses, as it may be that they are being dissipated mostly at the negative side, before returning back as a positive spike.  What do you think?
  At first I thought that the Joule thief may work similar to the TPUs, but the more I look into it, and investigate, it does not seem like that to me now.  Although there can be similarities, but , there are no Joule Thiefs that can start a car, like the MITTS's dome device.  Which is the only other device that is  about the same size as the SM units, that has been shown as having that kind of power and that kind of CURRENT.
  I also think that amount of Mass in the unit is also very important, as you can not start a car, or run your house, with a match box sized device,  at least not yet.
  I now feel like that what is needed is more like a Scalar Wave device made using coils, capacitors, diodes, etz., with very quick and short field reversals. It may be that magnets are also helping with those abrupt occilations, as the chatter or vibrations may be just that (occilations), and the giroscopic effect may be the vortex spinning inside, possibly both ways at the same time while also switching polarities. The hash and heat may be negative and undesirable side effects to be worked on to further improve the performance.
    I am studing those Scalar Technologies and theories, now.
  So, Otto, thanks again for your honest answers, and my best wishes to you and your work.
                                                 NickZ
giantkiller
@Loner,
Lets say we have a circuit with floating ground. We bias the coil on constantly. Then we switch that off. The inrush or bemf is very quick to fill the void. The iron wire ground receives the pulse and the whole circuit rises up. The magnetic fields picks this up too. The whole circuit is now thumping attached to antennas, transmitting and receiving. This scenario is similar to the audio feedback loop of placing a microphone in the center towards a speaker. Posted this 3 yrs back. The analogy is we move the microphone in and out like the noise wavers the fields across the TPU. Kapeesh? The inrush is fast and free if we trap it to pulse another turn.
otto
Hello all,
@NickZ
yes, Im from ex Yugoslawia, now Croatia. Im working all my life in electronics but.....principals? In electronics? Im working on the TPU from the first moment Mannix posted the SM stuff. After only a few days I saw that a TPU is something different then I have learned in school: I had a negative resistance when I connected a bulb to something like a toroidal coil. In that time nobody knew how to build a TPU or something near a TPU. We knew only that it was a toroidal set of coils.
So, I saw that a classical thinking about a TPU was useless. Especially my education was useless.
Later I decided to build TPUs that nobody made. Tests that nobody made......
I dont want to talk about theories because they are all guesses and speculations but I can tell you where the extra energy - power is coming from: the TPU coils are able to "produce" it. Nothing from outside!! Yes, crazy.
Earlier, maybe a year ago or 3 months ago, if somebody would be crazy enough to wright this I would laugh. But today....
All I know is that not 1 device, from the oldest to the newest works on the TPU principals. This is totally new and never seen. And this is the reason the TPU is "burried" very deep.
Or, in other words, the TPU coils have at some frequency mixes negative resistance. Not only when you connect a bulb and then you see the current dropping. All the time the coils are pulsed there is a negative resistance.
Or, if I was not clear enough, Im talking about a superconductor!!
Ever seen a device that works on this principals?
Its cleverer to learn about superconduction and superconductors and not about scalars and the stuff where a device sucks extra energy from the outside.
You will find a lot on the net about superconduction but.......again useless because Im talking about superconduction at our temperature where we live!! Is this the so called "room temperature"?? And, not to forget, this superconductor you can buy, its a very cheap superconductor....
I hope the bad guys dont read my crap. Crap?
Thanks for the wishes. Only a very hard work will give the results.
Otto
NickZ
  @ Otto and All:
      Wow, thanks again for that answer.
      Yes, my father and grandparents were also from Yugoslavia, ( Zagreb).  And I have also worked before in the electronics field for over 15 years, mostly on PC circuits, and can build most any electronic device.  But, I am a builder, and not an inventor.  I have been following you All since the beginning, waiting for the moment that the SM invention would be replicated, but.... no luck.  Because of this I got impatient and decided that it was time to do something about it for my own sake.  It is almost inconceivable that such a simple device as the SM units has not be replicated in more than 14 years.  As it only has less than 10 components. But the secret of operation is still a secret to us. If it were not for his videos, nobody would have guessed there was such a thing.  I agree that NOBODY has been replicating it as it is.
   The Scalar devices are now being used for many purposes, including diverting the last storm Alex oil 1 from its course, also possibly causing the Haiti earthquake, and others.
Yes,  this is all speculation, but the Russians have huge third generation working scalar operations that are no speculation.
  My point was that the devices may be working similar to a Aether diode pump, and unlike (or like) a joule thief may not be recycling the energy that is already found in the device or battery, but instead pumping Aether energy through it, and later with a rectifier producing useable current. The capacitor is the Aether energy filter.  Tesla's Longitudinal Waves may be the same thing as Aether waves, and were known about many years ago.
  No device can produce power without that energy being replenished, and as SM devices have no outside sources or even batteries (possibly) where is the power coming from if not from the Aether?  Is this idea so inconceivable?
  The point is to reproduce the effect of running with gain, by  overriding the effects of entropy.  So, how can this be done, if not by using it's own feed back to further accelerate the device.  We have been afraid to do this thinking that it can blow itself up, but that would be the least of our worries, as we haven't been able to produce even one iota of electricity.
  I will considered your ideas also and hopefully we will be able to see some progress on this subject, soon.
  As I am far from an electronics supply center, I can't afford to to make too many mistakes, and have to be carefull in my approach.
  My greetings to all from Costa Rica, the sweet spot of perpetual kicks.
                       NickZ
e2matrix
I think there is a real strong hint in this document and I know GK has mentioned some of this before.  Look at the Fe56generator doc here in this post # 3098 in the TK thread: (this is the .pdf download link from here on OU)  http://www.overunity.com/index.php?action=dlattach;topic=7679.0;attach=45973
Nickz,  I'm not sure scalar is quite what we are wanting in the TPU - just a feeling and I think scalar waves can be very dangerous especially at higher power levels.  Read the document above and it may give some ideas of where I think the power is coming from.
