Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
Nihilanth
Hey, as long as you're not saying that it's powered by magic and unicorn farts, I don't see why not.
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
BEP
Hey, unicorn farts can be highly energetic!
@Wattsup,
Your perspectives are always interesting. Whattzup?
giantkiller
@wattsup,
wattsup do it?
CSI-Overunity is correct. It is a crime scene and we are the sleuths.
(I did meet a PHD in chemical engineering that works for the EPA as a investigator. She is a cute blonde gal just like on the tv shows.)
So,
I am putting all the pieces together into a bigger compilation.
Joule thief oscillator, cmos switch exciter, push/pull gate on fet, floating ground, dual magamp for 2 phase resonance into larger loops. Only the larger device, which to me looks like a step up, drives big loads. On the smaller TPUs it looks like the magamps are the TPUs resonating back and forth or up and down. All configs use resonant rise and can run on a 9 volt battery.
As a side: I was looking at the 3 coil transformer in the stun gun and have the notion that it act as a magamp.
This is what I see.
rensseak
Wattsup come on, do it. What shall happen, except that they see you as a sceptics. And?
Norbert
giantkiller
@wattsup,
Do it. I was given advice of "If they mock your efforts then they don't understand the mission".
Well, except if you are talking about dancing on your roof in a pink tu-tu with a TPU driven chainsaw! I am sure not many will follow.
