A validation of the UP-SIDE-DOWN phenomena
Started by EMdevices, November 02, 2009, 09:40:48 PM
turbo
Okay i went to the powerlines to analyze the spectrum  :)
I was happy to find a strong frequeny in the Khz Range.
When i got home i realized i was standing under some street lights  ;D
So pherhaps this was the source of the signal....
Tomorrow i will go between the cows where there are no street lights and measure again, although i still think the signal came from them lines.. :)
And even if it comes from the street lights, there is alot of power.
I can see it on the graph because if it's stronger the noise get's less.
Marco.
BEP
Better make sure the cows aren't doing it  ;)
Those little hefers can be pretty tricky around here!
dutchy1966
Hi Marco,
Nice work with the portable spectrum analyzer!! I wondered why you had to modify the PPC exactly.
Is the default setup not sensitive enough and therefore you had to go straight to the AD converter?
From your pictures it seems you're using an internal antenna from a portable radio as a receiver. Is that correct?
Be careful between the cows tomorrow!
regards
Dutchy
Spider
Hi Marco,
Nice job!!! :D
Enne.... Vat geen cow boy!!!
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
turbo
Quote from: dutchy1966 on December 01, 2009, 02:49:07 PM
Hi Marco,
regards
Dutchy
Hi Dutchy
I had to modify the ppc becuase there was no input connection available on this particular model.
So i took it apart and used the internal input from the built in mic.
It was close to going wrong so i won't reccommend it.
But it does work great.  :)
Quote from: Spider on December 01, 2009, 03:07:52 PM
Hi Marco,
Nice job!!! :D
Spider
Haha ik vat nie zomaar een cow hoor jongens  :D
Marco.
