Joule Thief 101
0 Members and 122 Guests are viewing this topic.
Quote from: ramset on March 10, 2016, 04:48:05 AM
MileHigh said
resonance plays no Part in ICE designs and any body stating  this was Clueless and obviously had no grasp on resonance... .
here is the simplest which any loud mouth clueless Putz should know
cavity resonance engine design
THE BUZZ BOMB
Ignition of the Argus pulsejet was accomplished using an automotive type spark plug located about 76 cm (2.49 ft) behind the intake shutters, with current supplied from a portable starting unit. Three air nozzles in the front of the pulsejet were at the same time connected to an external high-pressure air source that was used to start the engine. Acetylene gas was typically used for starting the engine, and very often a panel of wood or similar material was held across the end of the tailpipe to prevent the fuel from diffusing and escaping before ignition.The V-1 was fuelled by 625 l (165 US gal) of 75 octane gasoline.
Once the engine had been started and the temperature had risen to the minimum operating level, the external air hose and connectors were removed and the engine's resonant design kept it firing without any further need for the electrical ignition system, which was used only to ignite the engine when starting.
then Johan shares a 2 stroke which works on creating huge output based on similar [cavity resonance and a huge standing wave]
it is not an ancillary resonant system it is a complete resonant design.
which generates a Huge standing wave or ....simply doesn't work [work being defined here as 3-4 hp per cubic inch in a normally aspirated recip  or Over unity from an engineering perspective]
creating this resonant standing wave between the carb intake and the tailpipe end is the holy grail of the design in its entirety .
3 to 4 HP per cubic inch
stop with your moving the goal posts MH
you outright stated that resonance plays no Part in ICE designs and any body stating  this was a BS'r and Clueless and obviously had no grasp on resonance... .
WRONG
don't keep pointing to others... Look at what you said
YOU ARE WRONG ...PERIOD
just like you are completely wrong about your Intimations here that Brad and Smokey are Guru Posers
and clueless about resonance and many other things you try to say
stick to what you know.... you are good at that .
but please stop commenting on things which you are clueless about .
and resonance in mass and how it may effect  energy harvesting is NOT YOUR AREA OF EXPERTISE !!
YOU KNOW NOTHING ABOUT THIS
ZILCH
but that does not stop you from calling people that do seek anomalies in resonance or resonant Mass
posers and frauds and Nonsensical and Bs'ers  etc etc etc ad nauseum .
you know nothing about it ..just like your ignorant resonance and engine design statement.
but yet you flap your lips with the greatest of ease...
you lost a lot of ground [credibility] in this thread so far.
grab your shovel MH I am quite certain you are not done pointing to others and digging that hole
but one thing I can assure you of
if I was lookin to change this world and seek new energy sources... your two targets here would be way ahead of you on most peoples short list of assets towards that goal.
and yes I know its very easy to throw stones at guys outside the Box
I watch you do it all the time.....
you self righteous PUTZ
Bow your head !!!!!!!
Chet,
You are going off your rocker.  I have yet to see the true scientific and engineering definition for resonance being used in an ICE and that's what we are talking about here and my statement was made from that perspective.  I made it very clear that I am not an expert on gas engines so what's your problem?  If people could communicate effectively and articulate a point properly and explain the full context then things would be very different, wouldn't they?
What the hell does a buzz bomb have to do with anything?  Are you "showing me up" by talking about a bloody buzz bomb?  The answer to that is no, you are making yourself look unhinged.
Right now Brad and Smoky2 can't answer the two questions, so what are you going to do?  Beat me up in a crazy rant posting?
Quote from: Johan_1955 on March 10, 2016, 07:12:15 AM
A specially for Bill / Pirate, its about sound & feelings: https://www.youtube.com/watch?v=ALJtkogKY-Q
Or 'On the PIPE'!!!!!!!!!, like Adele can do!
Did have such a One, during the fake Oil crise in the '70's, uses fuel 1 ltr on only 8 km, with a silly-putty frame, getting cold here, why ...........
MamboJambo, sorry for mine grammatical disorder, almost no lust anymore, and time!?
All that I asked you to do was explain what your supposed resonance was for the first motorcycle engine revving clip you posted.  If it's some kind of tuned inlet port or tuned exhaust port with some kind of standing wave, I asked you to explain it with a detailed description, a mechanical schematic, and an annotated timing diagram.
You have done nothing of the sort.  I wanted to see if whatever "resonance" you were alleging had any relationship with the true scientific and engineering definition of resonance but I have zero information from you to work with.
And now you are going crazy posting all sorts of stuff, including old quotes from me.
Johan_1955
HelmHotz is working, but mostly only used as a correction related to design of space mismatch.
Look behind the cilinder, the Brown-Stainless bump on the exhaust-pipe:
Johan_1955
Quote from: MileHigh on March 10, 2016, 07:24:38 AM
So you're asking for the breast?
