Thanks to ALL for your help!!
IST ULTRACAP 2.6VCD TO 120VAC CONVERTOR
Started by innovation_station, November 26, 2009, 10:52:48 PM
innovation_station
I offer
all to replicate.. and take mesurments
1 12vdc invertor smaller the better ...  SO NOBODY GETS HURT!
1 120vac fullwave bridge ..
1 steel core
1 peice 12ga romex
1 peice 14 ga stranded bifillar speeker wire ..
operation of such a device is simple
pulsed dc 120v input ..  out put .. deturmined by turn count ..  out put ac 60hz ..  higher volts..
ITS JUST THE KNOWALGE OF THE COILS AND HOW THEY INTERACT!
innovation_station
here is a close up on the final ...
enjoy
try it see if it works ...
looking forward to comments..  8)
ist!
innovation_station
i only used the invertor so i did not need to make a 60hz pulser...
ist
for the 2.6vdc ultra cap a pulser of desired freq is required..  aswell as the proper core for the freq u desire ..
tuneing is also required ...  :)
NOW HOW HARD WAS THAT ....   AGIN YOU WILL FAIL TO PROVE THIS WRONG..  :)
innovation_station
if some one wants to design a 2.6vdc banger at 60hz i wont say no ...
ground loop im sure will make bords ...
should be able to deliver minum 30 amp at 2.6vdc constant ...  more if you want more ...
peace..
ist
1 stone to move yet ... speed of charge of THE POWER CAN .. its ok i got 550 1 inch toroides to find the best one  ;D ;)
when its all said and then done ... more will be said then done! ..
and this will run constant from an aa...  ;)
forest
Questions:
1. This white ring is iron or steel piece of pipe ? What is that covered by ?
2. What diameter ?
3. What about the output wires ? Because there are 4 ends of wires (2 x 2) - how them should be connected together ? There are two possibilities here. Bifilar as per Tesla (end of 1 to the start of second or something like that) or simply joining each wires of pair together.
4. I assume that black device is car inverter 12vDC->120VAC, right ?
