Ionospheric antenna get 5 KW free !
Started by Tesla_2006, March 12, 2006, 07:16:05 AM
the_big_m_in_ok
triffid said:
I bought an electronics kit at a yardsale and put together a crystal set from it and got .04 volts output from the earphone wires.I figured that 20 crystal sets going into one battery (20 times 250ma=5 watts per hour)might keep a battery topped off,if you don't use it much.Triffid
@triffid,
Are your sets in series?  .04 V @ .25 A * 20?
That would equal .8 V * .25 A equals .2 W  (series voltage)                   Furthermore,
                        .04 V * 5 A  is also equal to .2 W  (parallel amperage)
Is the logic right here?
--Lee
lltfdaniel1
Quote from: Qwert on January 29, 2009, 11:53:36 AM
I have mailed some questions to a guy who is the subject of this thread, using his e-mail addresses I found on his web-site. In return I received this:
Dear Marek
Thanks for see my web site of the Ionospheric system, yes , you are aright, there is not files for download, however here is a mirror in spanish with spanish available files you can download and translate, the english web site is under construction and all web sites must be updated and I do it when I have time
The spanish mirror is:
http://energiaradiante.tk
  There is 2 options for you can get one of this devices, or the starting 5 KW version we build in the past, the first is you can get the plans, schemmes and building guide of this device for you can build this device for yourself in your country, in that case, we can do a cultural exchange for pieces and components I need for build or give more performance to others systems now days I am testing and building, in fact, I can send a listing with the pieces and components I need and you choice some item for send. The second  option is send to you a builded unit of the kilowatts you need, in that case I need to know in what country you are for know the sending costs
There is too much variants in this devices type, for example some time ago we test using a yaggi antenna tuned to 7 MHz, we send pulses at that frequency and it travels around the Earth following multiple reflections between the Earth Surface and Ionosphere until the pulses returns rear the antenna, a complete cycle, that cycle timing is about 1/12 of second and then the antenna sends other pulse to 7 MHz adding more power to the previous pulse and then for each cycle power is increasing for this resonance method and the 7 MHz signal go down in power and amplitude and the 7,8 Hz component increases in amplitude and power and so with this method we get 12 KW in the first testings
For understand how works this principles you can see this video show a similar case:
http://video.google.es/videoplay?docid=5540717206741162529&q=marcos+magnets
You can see there, 3 permanent magnets and the maximal vibration is at 7,8 Hz and if the electromagnet send the variable frequency pulses can be in feedback with that mechannical vibrations the power output in the same will be too high
I am placed in Argentina this days
Thanks for you time and atention
Bests regards to Chicago USA
Juan
Regards,
Marek
I can not wait for these plans so i can build and as far as i can see this uses the earths own rf frequency for converting the earths rf power into usable electric.
Sure there are man made rf broadcast frequencys in the 80-100mhz whatever but not as low as this.
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
flathunter
Quote from: Charlie_V on January 29, 2009, 11:10:04 PM
For a 7.8Hz LC circuit, you either need a really big capacitor, really big coil, or both.  It would not be easy.
Old message, but thought this might interest some of you....especially as the Russians have been on the Kapanadze/Tesla discussion.
http://www.youtube.com/watch?v=5Td--HItuoI
Looks like someones been playing with some very big coils and capacitors.  This is no hoax.
triffid
test,need a link back to here.I still want to build a 5kw unit.But got stalled.I just recently learned how tap some Tesla energy(26 volts d.c. milliamp range) from the "tommey reed" video clips posted in another thread here.His experiments proves it exists(power from the atmosphere).Triffid
the_big_m_in_ok
hansvonlieven said:
G'day again,
I have copied a couple of images from the main file, they are below.
@all
The 2N3004 transistors are wired as a short with their bases together, along with both push-pull emitters?  The collectors are between the rails.
Does this work?  Even theoretically?  Is pese watching?  Tito?  Who has an opinion?  I've never seen transistors wired like that.
--Lee
