0 Members and 64 Guests are viewing this topic.
PaulLowrance
Quote from: gravityblock on January 16, 2010, 11:17:17 AM
Why you can't have a coil radius that is 0.5 cm in thickness when the total radius is 3.0 cm.  Lol
Once again, go to the calculator link and take a look at the illustration.  It clearly shows you how the coil radius and toroid radius is calculated.  If you follow these instructions then it is possible.
Paul said "Okay, there's something very different with what they call coil radius."  Don't blame me for what they call coil radius. lol
The toroid would be 0.5 cm in thickness when the toroid radius is 3.0 cm and the coil radius is 2.5 cm.
You prove once again you have poor reading comprehension.
GB
eh hem,  ;)
http://www.overunity.com/index.php?topic=8411.msg223144#msg223144
PaulLowrance
If it helps any, here's the data that I used to verify the following inductance calculator was in agreement with real measurements
http://www.mantaro.com/resources/impedance_calculator.htm#toroid_inductance
Calculator:
Toroid height (length) = 750 mils (1 mil = 0.001 inches)
Outer diameter = 1932 mils
Inner diameter = 1250 mils
Permeability = 5000
Number of turns = 1000
Results = 8294602114.270 nH = 8.29 Henry
Real measurements taken by Amidon:
Part number = FT-193A-J
OD = 1.932 inches (1932 mils)
ID = 1.250"
Height = 0.750"
Inductance = 7.435 Henry
gravityblock
@PaulLowrance:
I also came up with the same results with the 1,000,000 permeability using the calculator.  I'm really tired of AirStriker trying to prove me wrong in every thing I say and do.  There was nothing wrong in the figures I provided as far as being possible, and they were close to the same dimensions of the cores Steorn is using.  At least I am trying to make an effort in figuring this puzzle out.  I've released videos, provided links, trying to replicate and sharing my results, etc.
What has he really contributed here.  Absolutely nothing except argumentative statements.
GB
Bruce_TPU
Quote from: PaulLowrance on January 16, 2010, 11:19:53 AM
Hi Bruce,
There are two types of 2714A material for non-custom orders. One is transversely annealed, which has a permeability of 80,000. The other longitudinally annealed, which has a permeability of 1 million.
This page tells you that MAGAMP is square loop -->
http://www.metglas.com/products/page5_1_6_4.htm
This page that shows the 1 million permeability of an annealed 2714A core -->
http://www.metglas.com/products/page5_1_2_6.htm
I went through this whole mess with Metglas years ago. It's confusing, lol.
Thanks Paul!  I feel a lot better now...LOL
I found the following, on your link and it explains why they said what they said.
Maximum DC Permeability (µ):
Annealed (High Freq.)
1,000,000
As Cast
>80,000
That was where they came up with their other permeability number.   :)
I think we should be good to go!  I am making some mechanical changes to my entire set up in preperation of all of the arrival of ordered coils and magnets.  Precision is going to be needed...
Thanks,
Bruce
PaulLowrance
Quote from: gravityblock on January 16, 2010, 11:44:57 AM
@PaulLowrance:
GB
Thanks, we definitely need more people like you guys in this thread!!  The workmanship in this thread alone is amazing. Heck, I'm lucky to drill one straight hole per day. So my wobbly 1.1" orbo attempt's not going to do much, lol.
Quote from: Bruce_TPU on January 16, 2010, 11:51:29 AM
1,000,000
As Cast
>80,000
Thanks,
Bruce
I agree. Makes sense. Now lets hope Steorn does not have hundreds of turns hidden in their toroid.
