gravityblock
@Paul,
Your video looks promising.  Hey, we've been rescued once again by OC and iOn.  The coils are connected in series.  The messenger delivered us from doom once again.  I guess we all have a role here, but playing the messenger role isn't rescuing anybody.
The rescuing is coming from the source of the information and not the messenger who is delivering the information.  We would have figured it out anyways by testing in the replication devices.  I guess it makes some people feel better and they're better than everybody else because they can deliver a message.  This is really unbelievable how people are acting in here.
Keep up the good work,
GB
PaulLowrance
Quote from: Jimboot on January 16, 2010, 09:17:04 PM
Wow that is impressive! Re your pages you realise the date stamp is not conclusive. What do you want to achieve. We use a number of different crawlers & spiders to get that sort of info. I think we are all busy trying to replicate! :)
Hi Jim,
Geez, it would take like 15 seconds per link.  ;) At least give me 15 seconds and post the date stamp, no? Every evidence helps.
Hey, interesting idea about the crawlers. Will they crawl .asc files? I'm trying to get an archived date stamp. Any ideas anyone?
Bruce_TPU
Hello guys,
So...Gyula is correct, no?  Then the 1H should be divided by 4 if four coils are in series,  so this gives around 240-250mH for any one toroidal coil.
Is this correct?  So perhaps OC can find out, if the induction measurment we all saw was of ALL four toroids in series or of just the ONE coil?
Assuming all 4 in series, we have the wrong coils.  We need some fresh math and finding the correct metglas coil...again...LOL
Sorry that I missed your far earlier comment and question on this Paul.  You should have pushed the issue...it is important to have the correct coils.
Cheers,
Bruce
i0n
Quote from: gravityblock on January 16, 2010, 09:29:07 PM
@Paul,
GB
Alright, I'm done here. Sorry for posting information people were asking for. Clearly you can figure this all out by yourself as long as you have your snide remarks. I don't know why you feel the need to belittle everyone else as I never attacked you or your "interesting" theories.
Good luck to everyone else though.
gravityblock
Quote from: i0n on January 16, 2010, 09:43:59 PM
You're post and information was very helpful and we all appreciate it, but the rescuing once again part isn't necessary (that is you trying to belittle others and making side marks, not me).  Steorn said, "the coils are connected in series, but it doesn't really make a difference".
Please continue to be helpful here in any way possible.  The more people involved the better off we are.  There is power in numbers.
GB
