0 Members and 64 Guests are viewing this topic.
gravityblock
Quote from: i0n on January 16, 2010, 10:05:55 PM
You see hidden attacks in my posts that aren't there. I never intended to belittle anyone's effort in here, nor did I mean literally rescue. It's a common phrase. I realize that me posting information that is available to everyone is not of much help, nor anything special.
I will however stop posting anyway as I'm honestly afraid you will take offense to something I say, which will lead to further arguments that won't help anybody. Don't take it personally.
So enough off topic now. Good luck guys in your replication efforts and keep solving the puzzle.
I am feeling the same way as you are at the moment.  I am afraid to make any comments for the fear of someone calling me stupid, disrespecting me, or insulting me.  We don't need this.  We need you and everyone else to say whatever it is they feel is important, without all of the attacks.  I've been attacked and insulted in just about every post I have made.  There is no reason for it.  This needs to stop with everyone here, and I'm talking to myself also.
Please stay around.  You and everyone else is an asset here.
I'm sorry,
GB
k4zep
Quote from: i0n on January 16, 2010, 10:10:27 PM
One last input. I think he means it doesn't make a difference in the functioning of the device. It will work either in series or parallel. It does however make a difference in regard to the inductance. The full inductance is the sum of all coils, which means ~250mH does sound reasonable per coil.
Just remember gang, if you put 4 one Henry coils in parallel, you have 250mH but very low DC resistance. There is such a diversity of knowledge levels here that to one person it is very obvious and to others more obscure.  It could just as easily be 4-4 Henry coils in parallel and same measurement would be made.
Ben
PaulLowrance
I've always thought the cores were in series because it seems like that in one of the videos, but the question I've always had was how he had the inductance meter connected. It could have been measuring only one of the inductors.
lumen
If that ain't bad enough, I think we might need to recalculate the turns on the coils also.
Has anyone else calculated the supposed diameter and figured how many turns it would take just to cover it with a given gauge wire?
I mean just to cover it!
Bruce_TPU
Quote from: PaulLowrance on January 16, 2010, 10:25:01 PM
Exactly!  This was my earlier point and question also.
@OC
Please find out the above for us and let us know...Thank You Kindly!
Cheers,
Bruce
