0 Members and 38 Guests are viewing this topic.
PaulLowrance
Another consideration is that Steorn may have wrapped the core with say electrician tape to separate thee wires even further from the core. This technique helps produce a more balanced applied field.
Jimboot
Quote from: callanan on January 16, 2010, 09:18:12 PM
Hi All,
Please see my latest video.
http://www.youtube.com/watch?v=CaWJrbfHxuo
I am testing a new Hub Dynamo that someone suggested, earlier in this thread, to use as a generator. I must say that I am pretty impressed with it's performance and high power output for reasonable torque input. It appears pretty efficient. The light bulb in the video is 12V 100ma and lights brightly even though the dynamo is rated at 6V 3W.
Obviously it is suited for low RPM use but a Steorn motor design could be implemented with this by using a large disk rotor.
Regards,
Ossie
Jaycar?
Bruce_TPU
Hello All,
Here is a short video of my new Steorn platform I am building.  Everything is going to be adjustable for precision and accuracy.
http://www.youtube.com/user/TPUBruce#p/a/u/0/GikG88I9ozo
Cheers,
Bruce
teslaalset
Regarding the measured coil value of the Orbo demo setup:
Are you guys sure that the coils weren't measured separately instead of in full circuit?
Another factor: the coil(s) were measured while the magnets were close to the coils. In that case the permeability might not be at it's maximum value.
You used 1.000.000 in your calculations; the value at those positions might well be 250.000 because of the presence of the external magnetic field.
After reading all arguments, I think you (paul, GB) are quite right with the coil specifics.
