penno64
Hi All,
There is some great work going on !
@Ossie. What inspired you to go with the wire core and where are you sourcing your enamelled wire from and how many mm is it ?
Guys, what I need help with is a 555 Monostable one shot. I have found many examples on the net, but not sure what values to use. I would like to feed the hall effect pulse to trigger the 555, then be able to adjust the pulse width & length to drive the scr.
Can anyone give me a helping hand ?
Kind Regards, Penno
Bruce_TPU
Hello ALL,
I continue with my slow methodical build... ;)
Here is my latest build video.  I am seriously detail oriented, as if you couldn't tell!  LOL
http://www.youtube.com/user/TPUBruce#p/a/u/0/jVdjMogZ2cI
Cheers,
Bruce
k4zep
Hi All,
I received my cores yesterday.  Interesting the results.  They do NOT pull in as strong as ferrite but what they do is most excellent.  With about 45 turns on a core, my inductance is about 1mH but the best part, when saturated, the inductance is only 6-7uH!  A huge swing.
I hope later today to test the viscous properties of a coil in a real motor situation, real time to determing the BEST pulse width to the core relative to the angular difference of the magnet. I suspect that best point is  near TDC with resultant highest saturation of core.  It is all time dependent.  There is a demonstrated definitive time lag to this viscous pulse, it will by the mechanics make the motor a very speed dependent device.  The width of the "Power" pulse must be short enough not to interfere with the later viscous pulse and thus, the motor does become a somewhat 1 speed device when in its best OU condition.
The ugly fact is that the viscous pulse is in the  toroid core and hence contained inside the core so it can NOT add any mechanical energy to the rotor directly but you must use the pulse (not CEMF but VEMF [Viscous EMF])to add energy back to the electrical side of the system (battery/Cap./ etc )and then use it elsewhere or back into the rotor cores to keep it ou, as there are very finite units of voltage and current where the coil is working at its best. There are other possibilities that will have to be studied as time goes by.  On further thought, there is a way the OU inductive magnified VEMF pulse can add energy directly to the rotor.  There are so many things that have to be taken into effect.  Steorn has not even started to go into the effects of the LARGE VEMF pulse!
Pic. of one of 16 coils.  I am using 1 magnet, two coils instead of 1 coil/two magnets.
k4zep
Hi Gang,
Viscous pulse in a MetGlass core.  Non canceling mode  first.
http://www.youtube.com/watch?v=qu21E9s29ZQ
Respectfully
Ben
