0 Members and 42 Guests are viewing this topic.
Bruce_TPU
Hello All,
Going back to the build...LOL  I continue to make new progress.  Here is the latest.  I am slow, but it is gonna be nice..very soon!  And I have some VERY unique ideas for the generator side when that comes.
http://www.youtube.com/watch?v=0tLwsJMwwJA
Cheers,
Bruce
http://www.energyfreedomreport.com
Jimboot
Ok the d cell was down to .8 this am & the motor had stopped. For the hell of it I hooked up the 6VSLA batt again I get 7000>RPM bit of fun but the volts keep dropping. The mototr will run on 0.6v & still get 1200RPM tho. More tuning to do
vorrex
What an anti-climax!  ::)
Not only do steorn not have it available on their website, they're still showing the loop ad for it. No one has yet uploaded it to youtube either... I wish I'd recorded it now - there was a couple of screenshots I want to take a look at again.
callanan
Quote from: woopy on January 30, 2010, 05:51:52 PM
Hi all
thank Ossie and Jean Louis Naudin i can understand better how it works
picture 1  a replication with 4coils of about 1 ohm resistance  = good results but you can see on the trace that the impulse voltage is higher than the generative voltage  = long run but no OU!!
¨picture 3, 4 and 5 = new setup with 4 coils each of about 5 ohms  = the trace shows a short impulse current about 1.2 volts and a strong 2.1 volt generative wave.  But i can not get the timing to INSERT the motor impulse IN the generation wave    any idea ??
THE TIMING  IS THE KEY (+ a lot of determination)
good night
Laurent
Hi Woopy,
Get some schottky or germanium diodes and connected them directly across the battery then control the current to the coils with a series resistor from say 0-100ohms. See the latest circuit on JLN's website. Use a variable resistor for better adjustment. You can also just use one series resistor/variable resistor instead of two.
Use your scope and get that input pulse inside the generator pulse. Yes timing is of most importance. Place each reed switch next to a different magnet. Have one oriented vertically and one oriented horizontally. I have found this is the best method of placing and adjusting the reed switches for me.
Regards,
Ossie
Bruce_TPU
Hello ALL,
Coils are wound, magnets glued and simply need to tune the toroids to the neutral line tomorrow.  Soon I will be ready to take it for a spin... ;D
This is the latest, from a few minutes ago:
http://www.youtube.com/watch?v=bk8vMIKPWGg
Cheers,
Bruce
