0 Members and 38 Guests are viewing this topic.
PaulLowrance
Quote from: teslaalset on February 07, 2010, 03:36:14 PM
I'd like to further discuss the input energy spend on the Orbo as demonstrated by Steorn in their latest video's.
There is still something I don't understand about the integrated energy curve of the input of Orbo.
We can distinguish 3 phases:
1) In the integral curve, the first part is climbing until 25 degrees from TDC.
A horizontal part means consumption is zero.
2)Then the curve is diving very steeply, meaning much electrical energy is produced in a very short time.
3) The last part of the integrated power curve shows a slow declining part, also meaning electrical energy is produced, but at a slower paste.
I can understand the first part. This is where the coil is powered.
But what is causing the electrical energy generation in 2) and 3)?
Can we exchange some thoughts here?
The attached image should explain it. That's how it seemed to me from the start.
Bruce_TPU
Quote from: maw2432 on February 07, 2010, 07:20:10 AM
Bruce,   nice looking coil.  Did it saturate?    Could you please explain how you shorted the secondary?    Thanks.
I just received 4 of those toroids and was wondering how they should be wound.
Hi Bill,
I will let you know in a bit, as I am just having time to play... LOL
You wind the secondary, strip the leads and join them together.  That is it.  They are not joined "electricaly" to the circuit, if I may use that word.
I will let you know if it works!
Cheers,
Bruce
http://energyfreedomreport.com
PaulLowrance
As everyone should be able to see, it's very simple. No need to subtract anything. Very simple equation, I^2 * R. The R is the coil wire resistance. The blue trace is net input (from battery), brown trace is output from pickup coil, just as Sean said. No mystery. No silly .99 misunderstandings.
skcusitrah
2) [is explained here]
No diode is used in Orbo.
No energy goes back to battery, as shown in post.
PaulLowrance
Quote from: skcusitrah on February 07, 2010, 04:34:49 PM
Wrong. Sean said from start there's a diode. They would be wise to use a simple rectifier in this particular demo to show higher efficiency.
Of course they are. Look at the integrated power plot.
