Hydrogen Efficency and Power
Started by wizkycho, March 13, 2006, 05:03:58 AM
wizkycho
http://www.shec-labs.com/calc/fuel_energy_equivalence.php
1liter (1kg of water) contains 111grams of Hydrogen atoms and 888grams of Oxygen.
1g of H, burnt or exploded in one second releases 140400W per second. folks it's 140.4kW/s !!!!!
If one is capable of disociating ONLY* 10ml (10g) of water per second the one is capable of releasing that much power.
1ml (1cm^3) per second would mean 14kW !!!! and it's enogh to make our homes warm as hell at winter times.
*someone should meassure how much water is "LOST" through time and easily find energy equivalent.
coversion back to electricity should be done with kinda "OLD" steam piston engine which can have 90% efficiency.
wizkycho
I have started another set of experiments and have a video of tap watter electrolysis 25A at only 4V7 (24 plates 1.5mm spacing ss plates). It's 66MB big and can't find web space to place it.
And today I'm filming 25 plates with 1mm spacing. If I make movie smaller bubbles are not well defined. please someone can you publish it ?
Dear wizkycho,
this are H-bomb numbers,
only to receive through "no limit space",
probably the name Sacharow gives a "KLICK" ,ZAR-bomb!
"warm as hell"- nomen et omen.
S
  dL
wizkycho
Quote from: lancaIV on June 08, 2006, 07:45:21 AM
Dear wizkycho,
S
  dL
You must be joking,
14KW or 140KW is not nearly close to H-bomb. Otherwise Your car is equivalent to 10 H-bombs.
besides I don't think fusion or fision is the right way because it creates imbalance and more problems... so i'm not going your destructive way.
Wyzkycho,
at first I think and write about H2 and not H(elium),
second the ic-engine is an open-cycle explosion-engine,
most of the power is lost-the reaction is to slowly,
and when you calculate 140KW/s:how compressed
is your "process converter" ? mm^3/cm^3 ?
These 140KW/s are 504MW/h per gram H2 !
S
  dL
