Gravity wheel of Mikhail Dmitriyev
Started by hartiberlin, December 08, 2009, 01:45:22 PM
andrea
Quote from: nickle989 on November 20, 2011, 08:26:28 PM
Software is not the answer one needs to build a real unit.  A ratchet effect will be need to hold the lever from falling back as it passes the equal point.  An excelleration will occur in as the wheel comes down.
Here you have the file, if you want to try. Yes, a software simulation is not the answer but it's a "start".. Btw, the ratchet effect seems to me very complicated to realize, cause when the wheel rotate there would be a system for "relaxing" the ratchet and allow the the lever to falling freely.
Bye!
johnny874
Quote from: andrea on November 20, 2011, 08:56:59 AM
Hello, I was curious about this work and I've replicate it with Algodoo. I've tried the version magnet-assisted (look at the draw made by mr. Dmitriyev). Results: the wheel doesn't rotate, cause the magnets effectively assists the wheel, yes, but also in the opposite direction.
BTW, that software is great!
  Andrea,
There is something simple you can try with magnets. Have them at an angle.
It is possible when passing the magnet, it's field
is also passed. If so, shielding would not be needed.
        Jim
edited to change pic
Low-Q
What do you think will happen to the wheel then the magnets is suppose to repel the magnets on the wheel? The repel must neccessarily act force in the opposite direction of rotation in order to unbalance the wheel. Therfor you will not gain any extra energy. You could likely use a lever to mechanicly push the weights out of position instead of using magnets.
Vidar
Yep.
It would be even more beautiful without that big ugly blue MULTI HORSEPOWER ELECTRIC MOTOR driving it.
