Cooling effects in Steorn eOrbo
Started by PaulLowrance, December 26, 2009, 11:45:15 AM
MrWolf
Hi,
I cannot build replication myself right now but here are some key points I would try out:
- use modified magnet-wheel as rotor for homopolar generator to harness output
- use magnet(s) behind toroid(s)
- use toroid(s) with iron powder core
- use PC as controller (wheel position to parallel port, toroid(s) state from parallel port), this would give rapid automated testing/optimization possibilities
- use V-track magnet arrangement and toroid(s) to overcome sticky-point
- harness heat energy from toroids using low temperature stirling engine (this is a bit mad but why not)
PaulLowrance
The spinning magnets do not effect the IR gun.
Again, the measured temperatures went *BELOW* ambient temperature. So it is not due to circulating air.
Last night I completed the control experiments.
I am now convinced this is a real cooling effect. I'm now convinced it is possible to capture excess energy from magnetic materials. It seems that it might have something to do with the state of the magnetic material. Beyond that I have no idea. It could be something as simple as the way the domains are structured. Magnetic domains do not form pretty perfect little symmetrical formations. Another option is the effect could be from an unknown source of energy.
Over time the effect fades. So anyone working on the eOrbo replications are highly encouraged to measure temperatures from the start.
All of the details are on video. So I've replicated it many times. By last night the effect was totally gone, and last night, after trying to replicate it I learned that there is no way to get the temperature to drop like that. In fact, it increases above ambient, not below.
The effect is *not* due to air circulation. In the video the temperature dropped like a rock as soon as the dremel was turned on. And the part of the video not shown is where I disconnect all of the clip leads and the temperature begins to increase to the normal ambient temperature. So it is very clear to me in that particular case the wire connections were somehow aiding the effect.
What is interesting is that this effect fades with usage. I have seen this effect countless times in peizos & diodes. The Steorn eOrbo has shown the same effect. Look how often they have to replace the eOrbos. I don't buy the story of the relays failing that often. Even the steorn guy said he's puzzled. Also, I question that the 1st Steorn demo years ago had anything to do with the bearings. This effect could be due to an unknown source of energy, that varies from location to location, or that varies over time, or varies with usage. What if the first Orbo machine ran just perfect at the Steorn building, but after running it for awhile at the demo location it failed.
And lets consider the major issue with cold fusion. Anyone who's seen the recent 60 Minutes TV show interview saw that cold fusion was verified by an anonymous scientist, but the issue they are having is ... once again "stability!"  And so far they have been unable to solve the cold fusion stability issue.
And then there's the incident that occurred years ago during the start of my magnetic research where I was doing an experiment to try to capture ambient thermal energy via a magnetic core. I was using the computer parallel port via software to control the pulse timing. There input source was a capacitor, and the output went into charging capacitors. So the total input energy & output energy could be calculated. And yes, I was well aware of dielectric absorption. Time after time it would not work. One morning, without changing anything, the first thing I did was run the software, and to my surprise the charging capacitors charged far above the cop>1 point. And what was weird is that the magnetic core made the strangest sound like I've never heard before, like a deep breathing sound. I was never able to replicate that.
Oh yes, and there's my MCE (magnetocaloric effect) experiments, which also showed the same effect in that the magnetic core was highly unstable in terms of showing MCE at room temperatures. Time after time I saw how the MCE would show up during the first few measurements, but would fade over time. This was seen in various different types of magnetic materials. The mystery was never solved.
So there is something very strange going on.
PaulLowrance
Quote from: Craigy on December 27, 2009, 07:32:44 PM
What about a control test? Replace toroid with something of same size / shape in same position and see if the cooling  reoccurs to object.
I did that last night. The effect did not come back. Also last night I completely removed (not replaced) the magnets to realign them because they kept getting way of out alignment with usage. Anyhow, I did not place enough tape around them, only one layer, and one of the magnets went shooting out of like a bullet, lol. So early this morning I had a chance to take a look at all of the NdFeB magnets with magnetic viewing film, and they appear to be normal, at least on a macro scale. Today I'll try to replace the magnets.
So the toroid was replaced with a different one, but somethings very different because the separation distance between magnets and toroid is a lot higher. So I'll have to look at the video again to see if there was a spacer under the toroid.
Since the setup was all apart, I had a chance to run the dremel by itself, and it does vary by itself. That's not to say all of the varying rpm is due to the dremel.
Quote from: Craigy on December 27, 2009, 07:32:44 PMI belive this is just local cooling from rotor but could be wrong..
I can now say for certain that is incorrect.
Magluvin
It would be great to get rid of my power consuming A/C system in my house and get me a couple dremels, some mags and a couple toroid cores and chill.  =]  My car can use one also. And a couple cordless for my shoes. AHHH
Mags
PaulLowrance
Also I cannot say for certain if at least some or most of the chilling effect is from magnets. When analyzing the video, it's clear that the IR gun was pointing at both the magnets and toroid, but mostly the toroid.
