Buoyancy/gravity wheel - another approach?
Started by Low-Q, December 28, 2009, 05:29:09 PM
norman6538
Sm0key2, could you detail your formula a little clearer and where each takes place.
ie m, I assume to be mass
h, I assume to be height
d ??? displacement
as I see it there are  6 work inputs
work 1. the object is inserted into the water displacing water and moved to the tube.
work 2. lowest valve is opened
work 3. object rises to valve 2 and valve 1 is closed
work 4. lowest valve is closed
work 5. upper valve is opend
work 6. object kicked off the water to do some work out
fredenergie
    Hello everyone, I am from France, I offer my concepte, if you are interested in her by her and chat with me, thank you for the questions                                     http://overunity.com/15847/total-mouvement-autonome-france/msg454472/#new
tagor
Quote from: fredenergie on July 02, 2015, 09:10:48 AM
why are you spamming ?
fredenergie
sorry no abituer the forum, how I can remove about thank you ???
RomanEmpire
Quote from: sm0ky2 on July 01, 2015, 08:08:06 PM
someone builds this..... may just win that prize  :-\
And the winnwer is: https://www.youtube.com/watch?v=UGPEOlQ2_uA
I think this is very close to your drawings except for the ejection system of the spheres which occurs by the thrust of the other floating spheres, and for the system of reintegration of the sphere in the riser tube, which is covered by the acceleration in the fall . The balls seem to slow the fall as they pass through the square boxes, maybe there are magnets in the ball and in those boxes there are coils that capture the energy and slow down the fall
