Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
agentgates
Quote from: teslaalset on January 12, 2010, 10:18:37 AM
One simple question:
How do you connect your oscilloscoop probe?
I connected mine with the ground lead to one coil connection and the signal lead to the other coil connection.
Would be good to know if you did exactly that as well.
Oh, sorry. I have forgotten to answer that question.
I have tried both ways, it doesn't make any difference, even with load on it.
turbo
Quote from: agentgates on January 12, 2010, 08:33:24 AM
@marco
The video you've posted is embarrasing but also extremely funny. All those coils have exactly the same problem and I am wondering if any of you were able to expect serious results.
That's why you are here right?
To show us how it's really done.....
I sugest you bring it on.
agentgates
Quote from: -[marco]- on January 12, 2010, 10:34:41 AM
Yes marco. Thanks for pushing me it is vital. Please make a bot repeats your comments every hour. :)
Magluvin
Wow Marco, your like a 7 star general!  =]
I agree though. Why do these things always go in this fashion. Hopes are raised, then replication failure, hopes are raised, then replications have mistakes.  But the one that says it is, wont show. There must some reason or mind set that leads the show in this way.
Gates, there is always the possibility that you could get shut down, just a thought, before we get a full view or totally understand.
You said earlier for us to copy all this, and you want the world to have it. If it works and Tes shows one working before you, im sure you will still get the prize.
But some things seem to be held back. We can only guess why.
Magluvin 0 7
teslaalset
Well,
I tried 50% duty cycle signal as low as 75 Hz, increased the primary peak current from 300 mA to 600 mA. It's a no go.
Next, I will make a new coil with 45 degrees single winding primary to see whether that will work for me.
[update]
Yes, I tried switching the polarity of the primary.
Yes, I tried turning the coil setup upside down.
Yes, I tried a 32 ohm load to the secondary coil.
No go, guys.
Below some details of my failing coil, just for the record.
Primary coil wire : 0.2 mm
Secondary coil wire 1.52 mm, 3 windings
