Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
mrd10
continued, i just used .3mm enameled copper wire, see the yellow tape, it says 6, which means 6 windings, that is the feedback coil, it doesnt have to be many windings, I made another small toroid with 10 segments instead of 3 as the ones shown, cause somewhere down the track i will hook 8 secondaries to bifilar twisted segments on larger tpu..
so you can see where im going with this........if you can visualize it...
mrd10
Hey giankiller, nice cct, thanks for that, hmm I could modify small toroid using your cct. but building yours and testing it first, cool
wattsup
@mrd10
Good work there. I will be very interested to see what type of coupling will occur with your epoxy/ferrite coated toroid.
mrd10
@wattsup
yeh me too, cause i just started again, i just allocate 3 to 4 hours aweek for this, so give me time, no rush on my part.
just to let you all know ill be absent for few weeks, so if it goes quite from me you know why.
it could work just as well without epoxy, but cause i made few nylon rings, i thought id coat some, and test that first.
any ideas we can share amongst each other might make all the difference.
e2matrix
Quote from: giantkiller on June 23, 2010, 12:13:44 PM
Yep, yep, yup!
Just change the output coil.
So stun guns have an internal spark gap before it goes to the final coil for the external (shocker pins)?  Change the output coil?  in the stun gun?  to the TPU control coil ?  one for each?  Lost... I know but I remember you said something about using stun gun circuits before regarding the TPU.
