Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
0 Members and 20 Guests are viewing this topic.
agentgates
@Lindsay
Thank you for your positive comment as always. It also helps me to work faster as I cna get lazy very quickly.. :D
And thanks for the useful advices to others and helping them.
Unfortunatelly I don't have cro (died a few months ago hand in hand with my PG due to another TPU experiment :D ).
BTW, what is your experience with the Northern/Southern hemisphere thing. Do the winding and polarity make a difference?
FatBird
Tony, Thank you for telling us about how you had one of your TPUs Melt Down.
It reminded me of how Bob Boyce's TPU caused a Lightning Bolt to hit him inside his garage when he got his 3 FREQUENCIES TOO CLOSE.
http://waterfuel.100free.com/wf_boyce.html
Serious warning needs to be given here. The combination of sharp pulsing and accurately wound toroid core composed of an iron powder matrix, draws in so much extra power from the environment that it is essential that it is only used with the electrolyser cell which is capable of soaking up excess energy surges. The extra energy drawn in is not always constant and surges can occur which can generate currents of 10,000 Amps. It should be understood that this electrical current which we can measure is only the 'losses' part of the real power surge which is in a form which we can't measure as we have no instruments which can measure it directly. Consequently, the actual environmental power surge is far, far in excess of this 10,000 Amps. It is very important then, that the electronics board and toroidal transformer are NOT connected to other equipment 'to see what will happen'. Even more important is not to arrange a pulsed, rotating magnetic field in the toroid by sequential pulsing of coils spaced around the toroid. These arrangements can generate power surges so great that the excess power not soaked up by the circuit (especially after it's instantaneous burn-out) is liable to form the ground-leader of a lightning strike.
Bob experimented with this and was hit by a DIRECT LIGHTNING STRIKE. He was very lucky to survive being hit and he now works in a worshop which has metal walls ans roof, and lightning grounding at each corner of the building, plus a separate ground for the equipment inside the building. A device like this is not a toy, and it demonstrates the incredible level of free-energy which can be tapped by quite simple devices if you know what you are doing.
teslaalset
Quote from: agentgates on January 12, 2010, 05:37:28 PM
Only the diameter bigger 127mm to make larger gaps on Stefan's device as it is from acrylic and perhaps he wants to take it to presentaions or other things and show people there are coils and no flat batteries around... :D
BTW the secondary is also different but ignore it, you have nothing to do with that yet. I use 3 secondary. 2x200V for inverter and another one for ~30V to comply his request on self-driving.
What's the height of your new coil?
teslaalset
Quote from: Mannix on January 12, 2010, 05:36:08 PM
The thing that is important is that I was not able to see this this effect clearly untill i switched ranges on my cro.
That is still the case and different istruments display this differently.
This experience surely is important for every body and I dont have the answer
I thought" no go" for a while as well but knew that Tony was surely getting something.
@ Tony do you have any thing to add on this ?..like try and older cro.
The folks here may be suffering the same as I was just to see the effect.
I would suggest that everybody try this.
Follow Tony,s advice over and over
If you are sure everything is correct, including the nature walk.
use a single turn of thin copper pipe, or thick wire. Hold it   above the unit with cro leads connected  to just below trigger level, in one shot if you like but it makes no difference.
now lower the ring over the running unit and see if it triggers..ok nothing? turn the ring over !
I needed 22 volts to see the effect but 30 was better
I hope that this at least will show you that there is something that the cro is picking up but possibly not displaying as we would expect.
@ marco, and others of doubt
Just wind one of these , one more ..it will be so easy for you ,it does not take very long.
It does not cost much. and so what if you dont get any results. have a go
remember marko rodin?
We need your help here . Whatever ......it is at least very, very  interesting.
@all
please work hard to get to see this effect IT IS THERE !
Tony ,Thanks again. It is a fine thing you are showing and I admire the way you are handling it.
Lindsay
The spike is so nasty and small that the maximum bandwidth capabilities of oscilloscopes matters. Any device capable of max 20 Mhz is no good.
The reason why higher voltages work better for you is that the current in the primary is larger, which will give a larger spike while switching off.
(according to my insights, but I looks like Tony has additional effects too).
update
The quality of your scope probes matters too, of course  ;)
ketone
@agentgates...i know what you mean about being careful putting on the secondary, very difficult little process,spaces were a bit unequal as well on this one, so i'll just use as a museum piece for now
I will paint the outside with glue first before attempting that again, so, on to build another one of yours tonight ...btw, has anyone had experience using wirewrap aka kynar? i can get to 33 awg and still have strength but unsure of shielding effect.
@mag...i hear ya...all credit goes to agentgates...and broli with insightful diagrams i've been wanting to wind
